Need Heating Advice
edited February 2019 in The Clubhouse
We’re down to Studs in the home theater and bar and I removed two old baseboard electric heaters. I don’t want to reinstall baseboards as they take up too much wall space. I purchased a Cadet 240v wall heater and programmable thermostat, got it installed last night and tried it out.
The good - it’s very small, low profile, and does a good job heating the space.
The bad - it’s loud. Too loud. Think hotel room heater/AC unit constantantly turning on and off. I hate it. Absolutely horrible for a theater room.
We’ve considered replacing our split system AC unit with a heat pump, but it’s expensive (like $4-$5k for a good one with two indoor units). Don’t want to go back to baseboard. Don’t have the room for something that sticks out from the wall more than an inch or two. I’m not finding much... would like something 240v, permanently installed and controlled by the separate wall thermostat. I’m thinking convection is the only thing that would be quiet enough. We do have propane available (near one wall), but most of what I’m finding is 8-10” deep (out from the wall).
Welcome!
    The electrical work is temporary - I know I’m going to get criticized for some of the wiring in the pics. :s The gang box with the two switches is temporary and will be replaced properly.
    We'll, since you don't want to do a heat pump, I suggest trash can fires. Cuts down on your waste to the local landfills and gives your house the sweet aroma of burnt styrofoam.
    I do have some styrofoam from the walls for a fuel source!
    And, not opposed to the split system heat pump. Just can’t swing that right now. We may have to go temporary (portable heater) for a year or two and then save for the heat pump.
    Not much to an electric heater. Basically heating elements, fan, safety switches, and sequencer. The only thing that makes noise is the fan motor, blades, and sheet metal.
    I would suggest looking at fan blades, should be directly behind that sheet cover, and see if they’re vibrating. Could simply be a piece of tape on one of the blades.
    If still noisy, with cover removed, and blades appear to be balanced, then look for something different.
    Depending on where you live and type of heating/cooling you use, I may have an idea or 3, but would try to figure out if noise is something that can be addressed or just a bad product design.
    Radiant Electric Floor Heating?
    Don't know the costs, but it's apparently quite energy efficient. Will just drive your electric bill up...
    Looking at that picture again, I would start by adding some bracing to the bottom of that heater and see if that cuts down on the noise.
    The noise is just the air flow noise. Nothing wrong with the fan. I guess considering it’s forced air built into the unit, there’s not much that can be done. It was described to us (before purchasing) as comparable to a running refrigerator.
    Radiant floor heat is definitely intriguing! Will have to research pricing. We could postpone carpet installation another couple weeks if we have to!
    What he said...
    Not sure if just doing the bar and walkway would be enough heat because I know you’d want carpet on the risers ...
    We’re abandoning the risers (two rows of seating) and going with a big sectional. The theater area will be new carpet over the concrete slab (padding too). The bar will be tile. The theater is 10’ x 20’. The bar is 8.5’ x 10’. The bar sits off too the right (as you look at the screen) all the way in the back of the room (L shaped).
    Al,
    Have you looked at or considered the ceiling mount options? A neighbor of mine has one and it seems to do a good job but not sure how loud they are. A guy in our neighborhood put this one:
    https://www.amazon.com/Fahrenheat-FSSWH1502-Fsswh1502-Output-120Volt/dp/B008GG7TX6/ref=asc_df_B008GG7TX6/?tag=hyprod-20&linkCode=df0&hvadid=198093463189&hvpos=1o1&hvnetw=g&hvrand=5274679828113163451&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9007798&hvtargid=pla-321270384155&psc=1
    into an addition and says it does great. Again not sure how loud it is.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
    Nothing to add here, except that I like that you've had the foresight to install a trapdoor in the slab. Wine cellar, root cellar, torture chamber... the possibilities are endless.
    Scott - the possibilities ARE endless! >:)
    So, part of what I’m up against... Makes me wonder what else is hiding behind our walls.
    This was discovered when we pulled the old drywall. And yes, it is live.
    Yikes. I think the guy who had my house before me was a self-proclaimed elektrishan. I've probably got stuff like that, too. Maybe not even taped up.
    scubalab wrote: »
    Great! Another place to install a wall heating unit :wink:
    scubalab wrote: »
    Noooooooo!! :s
    It’s like Russian WALL roulette!!
    Hello, we're so sorry to hear the wall unit is unsatisfactory. We would think with today's technology they could have come up with a way to reduce the fan noise perhaps by reducing the motor speed and/or advanced blade design.
    From first hand experience we can tell you that radiant floor heating is wonderful, but it does not work well if there is padding and carpet over top despite the claims.
    Good luck and we hope you have a wonderful day.
    Aaaaaand... he’s back!
    Missed ya Jesse!
    (I knew fan noise would draw you right in :p )
    Something is very wrong here...
    Stepford F1nut
    Or...
    OMG! Who is this guy? :smile:
    Interesting it’s that loud. I have two, one in our basement HT area, and they I can’t hear them at all.
    msg wrote: »
    Stepford F1nut
    Indeed, WTH happened to Mr. short and sweet?
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    lightman1 wrote: »
    Noooooooo!! :s
    That's a good example of why I stopped DIYing most home improvement. I don't like surprises.
    On the original topic of this thread, and FWIW, I love our Mitsubishi "H2i" heat pump thingy. This thing is claimed to be able to operate efficiently down to -12 F. I can vouch for it down to -10. No auxiliary electric heater in it, since it really doesn't need one. It is quiet, competent and very energy efficient, too. We had this installed last summer. So far, I am thrilled with it. In fact, if I had it to do over again, I might used these for the whole house when we had it built.
    We're using it as an auxiliary/backup for our propane boiler (and for some A/C in the summer), since our electricity is essentially free (via net metering).
    28569962627_289a775290_h.jpgDSC_1842 (2) by Mark Hardy, on Flickr
    29585856298_44f0ac5bed_h.jpgDSC_1840 (2) by Mark Hardy, on Flickr
    Jeremy, that looks like the same one I got (but mine does not have an on-board thermostat). I have another model that’s going back; I may try connecting that one and seeing if it sounds the same. I’m also wondering if once the drywall goes up if it will quiet down. I’ll not too optimistic as the noise is air flow noise. Right now, sitting about 10-15 feet in front of it, it’s very noticeable. It also doesn’t help that the thermostat turns it on for five minutes, then off for 5-10 minutes, then back on, etc.
  • So I just leave mine set to high all the time, but they are wired to a timer, so they’ll switch off on their own if I forget.
    I only flip them on if I’m planning to be in the HT.
  • I don’t know if the finished wall will help.
Welcome!
Welcome!
