Grommes Precision Model g-23
SIHAB
SIHAB Posts: 5,902
what do I have here? :*
@mhardy6647
  • SIHAB
    SIHAB Posts: 5,902
  • SIHAB
    SIHAB Posts: 5,902
  • SIHAB
    SIHAB Posts: 5,902
    passes smoke test. :#
  • SIHAB
    SIHAB Posts: 5,902
    I have a speaker that can do 70v at home so maybe later today...
  • SIHAB
    SIHAB Posts: 5,902
  • SIHAB
    SIHAB Posts: 5,902
    seems like this is gonna be a project :#
  • agfrost
    agfrost Posts: 2,498
    Jay
  • SIHAB
    SIHAB Posts: 5,902
    edited January 2019
    o.k. Powered on but needed a fuse. (this was key :D )
    It is unsurprisingly noisey.
    I plugged in an old TT as the RCA jacks fit.
    No gain. It does make some music when cranked up.
    After findings some smaller RCA ends, I plugged in
    a tuner. 20 Watts of SS power! (and a lot of noise)
    mhardy6647 Posts: 35,562
    Grommes made some nice vacuum tube amplifiers -- this little fellow looks like a small sound reinforcement amp of some sort.
  • SIHAB
    SIHAB Posts: 5,902
    mmm, Ducati. It says 4/59 on it so we can guess turn of the decade.
    edited January 2019
    It is not impossible but being all transistor would suggest its a few years newer than that. Transistors really became a big thing in audio in the early 1960s.
    A really good place to look for info on this (although it will require a certain amount of dedication, patience, and brute force are the technical resources (industry catalogs, etc.) at https://www.americanradiohistory.com/
    I will -- ahem -- peruse a wee bit myself :)
    edited January 2019
    ummm, errrm, ahh -- they're still around (or at least there is still a website - I didn't see any content newer than 2004, though!); might want to drop 'em a line or give 'em a call.
    http://www.grommesprecision.com/index.htm
    What you have there....is a pretty snazzy looking door stop. :)
    tonyb wrote: »
    A Mid-Century Modern doorstop, thank you very much.
    With optional cover screen, I might add.
    B)
  • ALL212
    ALL212 Posts: 1,690
    It's a PA or paging amp. Use caution when hooking up speakers to this as it means 70v! We've got similar in our plant and you can run wire a very very long way and with the proper speakers get a lot of volume.
    Aaron
    Enabler Extraordinaire
  • SIHAB
    SIHAB Posts: 5,902
    Thanks All. My Altecs can do 70v though I had never tried them that way.
    Paging Amp seems to be the winner! Door stop too!!
    Not surprisingly, at low volumes it sounds like an old transistor radio.
    Give some juice and it sounds o.k.
    No work for the next couple of days so time to tackle some more of these
    little projects. o:)
  • agfrost
    ALL212 wrote: »
    Makes sense with the mic input. SIHAB, time to put a vintage whole-house comm system in? :p
    Jay
