Iec 6DJ8 vs? Is this a Mullard?
erniejade
erniejade Posts: 6,321
edited January 2019 in 2 Channel Audio
Is this a Mullard? Great Britain made.
Anyone know how this tube is against a sylvania 6922 ?
  • erniejade
    Also is this realistic the same as the IEC 6dj8? Looks the same to me. 75atya1px5wj.jpg
  • erniejade
    Here is the story. I have a grant fidelity tube dac 11. It has a nice sylvania 6922 in it but. I have a few 6DJ8 tubes in my small stash to roll. Are the IEC and the Realistic the same tube and are they actually Mullard? If they are the same, before i install the tube dac 11, witch tube would you prefer and why?
    Yes i know i can just keep going between them but, once it's in place, it's not that easy getting it back out to swap so, i would like some opinions please.
    heiney9 Posts: 25,576
    I don't know a lot about 6DJ8's and their construction since I don't have gear that uses them.
    IEC were mostly rebranded Mullards in the 12Axx family, but really they could be anything. Do you know for sure Mullard even made their own 6DJ8/6922? And just didn't relabel someone else's.
    I don't recall w/o doing some research if this was the case.
  • erniejade
    I need to google it. When I got them a while ago. I was told they were Mullard but i do not know for sure so i thought i would ask.
    Mullards should typically have etched codes too.
    It appears they did, here are some photo's and you can see part of the codes.
    http://www.tubemongerlib.com/gallery2/v/6DJ8/?g2_page=6
    I also had a look at Tubeworld and he lists Mullards as well.
    Top line of etched code is GAx with x being the change number.
  • Thorton
    Thorton Posts: 1,324
    erniejade wrote: »
    Ship them to me and I'll let you know how they sound versus Amperex 7308's! B)
    Probably picking up AXPONA tickets this weekend. It will be here before you know it. Hope to see you and your wife again!
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • erniejade
    I already got a 3 day pass for me. Brig wants to go but shes not positive if its her Saturday to work. If it is, she can join us for dinner since we work 7 minutes away.
  • erniejade
    It seems like both are mullard from the ,60's from what i can tell. I think i will try the realistic gold pin version first in the tube dac.
