Rear speaker pairings for RTIA9 and Denon X4300H receiver with 5.2.4 setup
Currently have 2 RTIA9 for the L/R channel, 200W CSI A6 for the front channel, but keep blowing up my 2 rear channel speakers (3rd party) that were rated at 90W, but must not be.
Are there any low profile speakers that are not in-wall that would go well with this setup?
My guess is that you’re clipping your receiver, and luckily only blowing the surrounds lol. That is a nice receiver but NO recover can power those lcr speakers...you need a 2 channel amp for the mains imho...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Low profile speakers for polk main channels is basically a challenge. You can look at maybe flat response speakers from other brands. Most speaker brands have a sonic signature. I'm thinking you should check out Definitive Technology Mythos Series low profile speakers like the Mythos 9's or even the XTR series like the XTR-60. These might be a very good fit.
I gotta tell you I'm not a fan of mixing and matching brands. If your running RTIA main channel speakers I strongly suggest going with RT in walls for a low profile other then on walls. I don't know why you can't go in wall for surrounds.Dan
Either dan or I misinterpreted the question lol...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks for the comments - the only reason that I shy away from in walls is that the placement is a bit more permanent that anchor mounted speakers, with a 6 or 8 inch hole left if I ever decide to adjust the speaker placement.
I may just go this route though - if Polk Audio doesn't have any low profile.
Amazon does have some low profile Polk Audio OWM3 On-Wall speakers rated at 100W, but for in wall, the Polk Audio 65-RT In-Wall Speaker seems to be my best bet rated at 125W. Do these need enclosures?Post edited by benf35 on
