How stiff is your......cable
brettw22
Ok, so I need to get a few power cables and I'm all for getting a better than stock, but I have a Signal power cable that is almost unbendable and needs 12-18" clearance to make a turn or the cable will torque my amp's power supply port - unacceptable......
So....do upgraded cables exist that are not so rigid?
Sure. Get a Shunyata power cable. Aside from being some of the best at different price points, they are flexible.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Cullen Cable2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Ps Audio AC-3"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »Ps Audio AC-3
I was going through a bunch of boxes the other day and found out that I have a pair of PS Audio speaker cables.......no idea when that happened......comment comment comment comment. bitchy. -
Negative on the $500 price point cables.......comment comment comment comment. bitchy. -
Replaced my Signal power cables with Wireworld easier to work with and a better PC cord.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Supra lo rad, affordable, works great and ultra flexible- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That is a step up from entry level cables. I started with the $95 Venoms on my amps and was floored by the improvement.
https://www.thecableco.com/cables/power-cables/venom-14.html
Now for amps they have the Venom HC at $295.
https://www.thecableco.com/cables/power-cables/venom-hc-power-cord.html
You can go up from there.Lumin X1 file player, Westminster Labs interconnect cable
VH audio if you like DIY.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Somehow they won't be in stock until August........seems like someone has an ordering issue.comment comment comment comment. bitchy. -
If anyone is willing to wait until they are back in stock, this coupon code still works at Upscale Audio for PS Audio products, I just checked. I used it three times last year on AC5 cables and saved $$$.
He posted this back in April of 2018. Thanks @gmcmanAs of now, 40% off using coupon code PSAPOWER upon checkout at https://www.upscaleaudio.com/
