How stiff is your......cable
Ok, so I need to get a few power cables and I'm all for getting a better than stock, but I have a Signal power cable that is almost unbendable and needs 12-18" clearance to make a turn or the cable will torque my amp's power supply port - unacceptable......
So....do upgraded cables exist that are not so rigid?
  • BlueFox
    BlueFox Posts: 15,250
    Sure. Get a Shunyata power cable. Aside from being some of the best at different price points, they are flexible.
    txcoastal1 Posts: 13,514
    Cullen Cable
    EndersShadow Posts: 17,715
    Ps Audio AC-3
  • brettw22
    brettw22 Posts: 7,623
    Ps Audio AC-3
    I was going through a bunch of boxes the other day and found out that I have a pair of PS Audio speaker cables.......no idea when that happened......
  • brettw22
    BlueFox wrote: »
    Negative on the $500 price point cables.......
    gudnoyez Posts: 8,172
    Replaced my Signal power cables with Wireworld easier to work with and a better PC cord.
    VR3 Posts: 29,514
    Supra lo rad, affordable, works great and ultra flexible
  • BlueFox
    brettw22 wrote: »
    BlueFox wrote: »
    That is a step up from entry level cables. I started with the $95 Venoms on my amps and was floored by the improvement.
    https://www.thecableco.com/cables/power-cables/venom-14.html
    Now for amps they have the Venom HC at $295.
    https://www.thecableco.com/cables/power-cables/venom-hc-power-cord.html
    You can go up from there.
  • machone
    machone Posts: 1,561
    VH audio if you like DIY.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • brettw22
    Ps Audio AC-3
    Somehow they won't be in stock until August........seems like someone has an ordering issue.
  • Hermitism
    Hermitism Posts: 4,329
    If anyone is willing to wait until they are back in stock, this coupon code still works at Upscale Audio for PS Audio products, I just checked. I used it three times last year on AC5 cables and saved $$$.
    He posted this back in April of 2018. Thanks @gmcman
    gmcman wrote: »
    As of now, 40% off using coupon code PSAPOWER upon checkout at https://www.upscaleaudio.com/
