SDA 2.3 end caps cherry veneer
I made some end caps for the SDA 2.3 out of cherry veneer and have decided not to use them. They are pre-drilled so all you have to do is remove your screws and put them into these. I had them mocked up but decided to go with a different wood.
$75.00 plus shipping
moparnut@twc.com is the fastest way to reach me about these-thanks.
    pitdogg2 Posts: 26,932
    next in line if la2vegas passes
    nooshinjohn Posts: 25,879
    Will these fit 1.2TL as well?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Dang, Those are nice! Just finished rebuilding a pair of 2.3TL's, these would match all the wood in my Equipment Racks and the 3.1TL's.
  • verb
    verb Posts: 10,176
    Paul those are sweet! And by the quick response (1 minute), looks like you may have a small business opportunity! :smile:
  • erniejade
    erniejade Posts: 6,321
    Wish they would fit my 3.1's. Nice work!!
    edited January 2019
    Vultures :D:D:D.
    Yes they are nice. If la2vegas passes I'll buy for sure. Love me some cherry
  • Conradicles
    Conradicles Posts: 6,329
    Want to make me some for my SRS2?
  • pglbook
    pglbook Posts: 2,258
    Very nice. I'd also get in line if these would fit my SDA 2B TLs. With such a demand for the nice end caps you made, perhaps you should start a side business making more SDA end caps, lol. You do very nice work.
  • Thanks for the compliments! These are sold as of now
