SDA 2.3 end caps cherry veneer
mopar paul
I made some end caps for the SDA 2.3 out of cherry veneer and have decided not to use them. They are pre-drilled so all you have to do is remove your screws and put them into these. I had them mocked up but decided to go with a different wood.
$75.00 plus shipping
moparnut@twc.com is the fastest way to reach me about these-thanks.
next in line if la2vegas passes
Will these fit 1.2TL as well?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Dang, Those are nice! Just finished rebuilding a pair of 2.3TL's, these would match all the wood in my Equipment Racks and the 3.1TL's.
Paul those are sweet! And by the quick response (1 minute), looks like you may have a small business opportunity!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Wish they would fit my 3.1's. Nice work!!
Vultures
Yes they are nice. If la2vegas passes I'll buy for sure. Love me some cherry
Want to make me some for my SRS2?
Very nice. I'd also get in line if these would fit my SDA 2B TLs. With such a demand for the nice end caps you made, perhaps you should start a side business making more SDA end caps, lol. You do very nice work.
Thanks for the compliments! These are sold as of now
