Help With Set-up
Phil Dawson
I am finally getting to set up my 5.1 system. The front speakers are SDA SRS 1.2s powered by a Harmon Kardon Citatoin @ 200 W per side, The rears are SDA SRS 2.3s powered by a Harmon Kardon Citation @ 150 W per side and the center is a CS400 powered by a McIntosh 250 bridged to 100 W. I thought I would bi-wire all speakers. This is my first theater system so any help would be appreciated.
Thanks, Phil
Thanks, Phil
Post edited by Phil Dawson on
What do you have questions about?
I need help with speaker placement and any other tips anyone might have.
Thanks, Phil -
get a very large room to start with
scott:cool: -
Get an AVIA calibration DVD, too. It's got one of the best simple setup and calibration routines (easy to follow, walks you right thru it) I've ever seen. For a basic question like speaker setup, it rocks. Check the Club Polk Webstore for it.
MC -
I ordered the disk.
Thanks, Phil -
You will probably want a Radio Shack SPL meter to go with that Avia disc. The analog version is ~$35.
I think you should send them into colorado. the climate will do them well. If you want, I'll keep an eye on them.
They are in Colorado now and they do like the climate.
Thanks, Phil
