Polk DS7200SW DB25-DB25 Input Cable Delima
TECH_T
Help! I have a question regarding my Polk DS7200SW
powered subwoofer and Polk Audio RM Digital Solution DS-1 A/V Preamp
Processor Loudspeaker Receiver. These came with satellite speakers as a
home theater (HT) system as the Polk 700DS7200 I believe.
These two components connect via a 13' 25-pin DB cord that Polk included in
the package. Well that cable went missing after moving to a new city. Is
there a special non-standard cable that Polk made because the aftermarket
one I thought would work isn't after replacing it?
I've purchased a Planet Waves 5ft Core Cable Cable Snake DB25-DB25 screwed
it securely in connecting a audio signal to both units, even reversed the direction of cable, but the DS7200SW powered subwoofer light remains red when powered on, not green
when connected.
I tried resetting the receiver to its default mode, checked the fuse on the
subwoofer, wiggled the connecting input cable, but no luck. Here is a link to the system owner's manual:
http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20040128125700/Manuals/700/700DS7200.PDF
Polk customer service said "Unfortunately the DB25 cable has not been available in years.
I would suggest posting this on our Forum". So here I am.
Anyway you can help me out here? I'd love to be able to use this equipment
again but this snag is preventing me from doing so.
when connected.
Hello,
The DB25 was a standard low capacitance DB25 type cable. I'm not familiar with the cable you bought, but it sounds like it should work. Normally I would suggest reversing the cable, but it sounds as though you've already done that. The only thing I can think of to do is to spray some good quality electrical contact cleaner in the connecting sockets of both the preamp and power amp and make sure the connectors are not going into the sockets at an angle when putting them in.
Maybe check the continuity of the cable with a VOM?
Regards, Ken -
I tried all of the above and the Planet Waves snake cable was the culprit. Luckily a eBay seller listed the correct Polk Audio RM Digital Solution DS-1 Interface cable (Item# 201541248106) and gave my HTR gear LIFE AGAIN!
Thank you for your reply, Ken. -
Great, I'm glad it's working correctly now.
Hey, what is the model number on that subwoofer? I need one and don't have the model number to search
The sub doesn't have its own model number it was part of the RMDS1 and the followup RMDS7200 system. Which system do you have? I might be able to help.
Hi , I have the same problem , I lost my cable to connect the main receiver to the subwoofer. Can you help me to get fix ? I do have two old printer cable and i was thinking to cut them and reconnect the male of two ends....
thank you -
The connecting cable is a low capacitance DB25 type cable.
thank you so much ,
Do you think this cable will be good to get the receiver and sub-woofer ( final stage amplifier) connected?
https://www.amazon.com/Your-Cable-Store-Serial-RS232/dp/B0026K9KGC/ref=sr_1_4?ie=UTF8&qid=1522165253&sr=8-4&keywords=db25+cable+male+to+male -
You're welcome, the total capacitance of the cable needs to be small in order to prevent high frequency loss. The cable from Amazon doesn't specify this, but with it only being 6' long that won't be a problem, so it will work fine.
Would anyone know if you can use this Polk DS7200SW sub woofer without the DB25 cable? I was hoping I could use it like a regular sub with just one RCA or one coax type of cable/signal. If I can't then I guess I have to trash / recycle this sub.
Hello,
It could be done but it would need some effort. You'd have to figure out what the DB25 connections are and construct a connection box to allow signals to be fed into the bass amplifier. You'd also need to construct a suitable turn on trigger voltage to switch the bass amplifier on.
