Bi Amping
First post, been have been in and out of here for years.
I have a pair of SDA2Bs that I have had since new, and listen to them everyday still. I have replaced only the tweeters.
Years ago, I got a set of 2.3TLs for free..they worked ok. Each side had 1 dead driver, and I've been staring at them for years not used.
Just ordered a set of V3 crossover upgrades, hurricane nuts...the whole fun bag.
Ill test the drivers here soon to see which one(s) dont work, and get to that next.
But, I have the ability to bi-amp them.
If I do, do I need to cross over at the Amp either channel, or is it all still taken care of in the speaker crossovers?
  • I believe it is taken care of at the crossover level. Could be wrong, I am sure someone else will chime in as well.
    F1nut Posts: 51,721
    edited December 2018
    So, you have active crossovers and separate power amplifiers?
  • F1nut wrote: »
    Separate outputs on a Sony 5000ES, the rear channel can be repurposed to be a front bi-amplified channel.
    I dont have any surround channels..
    Clipdat Posts: 13,089
    speedtoys wrote: »
    I hate to break it to you, but that's not actually bi-amping, as it's still all coming from one amp.
    Just break down the meaning of the word "bi-amp": two amps. It means two separate physical amplifiers, two separate power supplies, two separate power cords, etc.
    F1nut Posts: 51,721
    speedtoys wrote: »
    How did I know you had an AVR.....LOL
    As Clipdat correctly points out, you cannot bi-amp using an AVR. It's marketing hype. In addition, no AVR will ever drive the 2.3TL's properly. They require a high quality integrated amp or separates to obtain the performance they are capable of.
  • Schurkey
    Schurkey Posts: 2,122
    Clipdat wrote: »
    speedtoys wrote: »
    A "stereo" amplifier has two amplifiers in one housing.
    A multi-channel AVR has a bundle of amplifiers in one housing. The problem is that they're typically crappy amplifiers, not that there's a heap of them in the housing. There's no engineering reason that someone couldn't build a decent AVR, the only thing stopping them is money. The AVR segment exists because folks won't pay enough to get quality product.
    It is ENTIRELY possible to bi-amp a pair of speakers using a multi-channel amplifier having only one power cord. Examples: ATI AT1804, Aragon 8008X5 (one channel un-used.)
    http://www.ati-amp.com/AT1800.php
    As said, with SDA speakers, you'll be using the Polk crossover unless you plan to disable the SDA circuitry.
  • verb
    verb Posts: 10,176
    Hey @speedtoys (love the name) first and foremost welcome! Glad you decided to jump into the fray! Lots of good advice here, hang around, and get the learning on! :smile:
    F1nut Posts: 51,721
    Schurkey wrote: »
    Clipdat wrote: »
    speedtoys wrote: »
    Yep and it takes two of those amplifiers to bi-amp.
    mhardy6647 Posts: 34,955
    There is much to be said for biamplification (or even triamplification), particularly --
    I'd opine -- with active crossovers. The best thing to do is almost certainly going to be use the right amplifiers for their intended jobs. Plenty of grunt for LF reproduction; outstanding linearity and sonics for midrange/treble.
    So, yeah, no matter whether one is going to biamp vertically or horizontally, at a minimum, at least a couple of capable amplifiers are going to be required for best results.
    Otherwise, it's just playin' around.
    Nothin' wrong with playin' around -- I do it all the time -- but we reap what we sow in this furshlugginer hobby. B)
    Playin' around -- a ca. 20 wpc Class AB solid state stereo receiver (hk 330i) used to biamplify a (monaural) Frankenspeaker system consisting of the bass unit of an AR-2ax and an Altec 802D compression driver on an Altec 511B horn (with a passive first order crossover). The "balance" control was used to normalize the wildly disparate sensitivities of the woofer and the treble section B)
    19729952203_bc4b8ff452_b.jpgnotzacklyVOT by Mark Hardy, on Flickr
    Also note the careful time alignment of the two components of the loudspeaker system.
    "Kids, don't try this at home!!
  • Thanks for the input all...
    Im no stranger to throwing money into a dark hole. ;)
    https://www.flickr.com/gp/28804666@N08/N6FsY0
    Separately, I have a Hsu Research standing tube Sub..bout 3' tall, I dont recall the model, being drivin by a Velodyn DC-600.
    Incoming Dumb Question (tm)
    Do 2 amplified outputs, even from the same AVR, supply any measure of "more" to each speaker?
    <End DQ Transmission>
    Even if I dont do it..Ill know more about why/why not.
    tonyb Posts: 33,069
    Not really, what that amounts to, especially with AVR's, is robbing Peter to pay paul….so to speak.
  • FestYboy
    FestYboy Posts: 3,861
    speedtoys wrote: »
    3dB if they are in sync, but that's as good as it gets.
  • delkal
    delkal Posts: 764
    FestYboy wrote: »
    speedtoys wrote: »
    Yep........ A lot of people think if you are listening to one speaker then add another speaker playing at the same volume it will be twice as loud. It won't. It will only be 3 dBs louder. You would need ten more speakers and amps playing at that level to make it twice as loud (10dBs). Of course its simpler to just turn your one amp up so it puts out 10 times the power.
    I have not Bi-amped anything so can not tell you first hand what improvements it makes. But it is not loudness. 3dBs is the slightest / barely detectable (at best) change when listening to music.
  • rpf65
    rpf65 Posts: 2,127
    Many people believe, on this site at least, your money will be better spent by getting some quality speaker cables and jumpers.
  • Schurkey
    Schurkey wrote: »
    Clipdat wrote: »
    speedtoys wrote: »
    You're correct for stereo amplifiers powering a pair of speakers, but it's also not helpful for the OPs situation. The OP has a multi-channel amp, and clipdat told him that using a multichannel amp is "not actually bi-amping" when it is, it's just being done with low-quality amplifiers stuffed into a single box with a single power cord leading to a compromised power supply. The fact that the receiver isn't optimum for the purpose does not mean that he isn't bi-amping, it just means he's using less-than-optimum equipment to do it.
    speedtoys wrote: »
    Depends.
    Using two amplifier channels per speaker cabinet will NOT increase the voltage delivered to the speaker drivers. Depending on how the receiver is set up internally, you MIGHT be able to deliver more amperage. If the transformer or the filter caps are the weak point, you don't get extra amperage because the power supply could be tapped-out from running two channels hard. If the output devices or heat-sinking are the weak points, you could get additional amperage since you'd be using twice as much (four channels).
    Listen and see...but I bet you're going through a bunch of extra complexity for no real gain.
  • delkal
    delkal Posts: 764
    If you use separate amplifiers / channels to power the high and low frequency of a speaker you are bi-amping. Even if the channels are all in the same box. No one ever said stereo amps don't work because they share the same power supply.
    Now if you ask would a setup using an AVR sound as good as buying a quality amp (even wiring the speakers conventionally) the answer is NO.
    But, If you are already biwiring is easy enough to find out if there is an improvement in Biamping. Just swap two cables to a separate channel and listen.
    I am more interested on how the OP modified his SDA's to allow for Biwiring/Biamping.
    F1nut Posts: 51,721
    Schurkey wrote: »
    Schurkey wrote: »
    Clipdat wrote: »
    speedtoys wrote: »
    speedtoys wrote: »
    Depends.
    One cannot bi-amp using an AVR with its single power supply, but even more importantly it's not bi-amping when using the passive crossovers in the speakers.
    http://sound.whsites.net/bi-amp.htm#common-question
  • dpowell
    dpowell Posts: 3,081
    I bi amp my 2.3 TLs using a sunfire signature cinema grand 400 x 5. It has the ability to place an RCA jumper between the main L/R channels and channels 4 and 5 allowing an easy second channel of amplification per speaker. I use the voltage source output to drive the lower frequency and the current source outputs to drive the upper frequencies since it provides more of a tube amp sound.
    This may still be technically bi-wiring since there is only once power supply in the amp but it has substantially more headroom than an avr.
    pitdogg2 Posts: 26,992
    dpowell wrote: »
    And that is excatly what Bob designed it to do
  • Schurkey
    dpowell wrote: »
    Nope, that's bi-amping.
  • Schurkey
    Wrong. Two amplifier channels per speaker cabinet (four amplifier channels per stereo pair of speakers)involves two amplifiers (bi-amps) per cabinet. It does not matter that they share a power supply. In the end, even four monoblock amplifiers would share power, even if that happens at the circuit breaker box in the home.
    "Bi-amping" is not the same as "bi-DC-power-supplying". We're counting the number of amplifiers, not the number of DC power supplies.
    From your own link:
    Passive biamping (where two amplifiers are used in a bi-wiring connection) is, IMO, a waste of money.
    I agree that "passive" bi-amping using the existing speaker crossover network as would be done with the OPs situation is probably a waste of time. I said as much in my previous post.
    It's still bi-amping, even if it's not a sonic improvement.
    F1nut Posts: 51,721
    With true bi-amping one power amplifier drives the high frequencies and a second completely separate power amplifier drives the low frequencies. Therefore, there are two completely separate power supplies, which most assuredly does matter.
  • Schurkey
    I entirely agree. However, separate amplifier channels does not equate to separate power supplies.
    It matters SONICALLY if the one, shared power supply isn't appropriately engineered. It's entirely possible that you'd get BETTER RESULTS with two separate amplifier chassis. But we're not talking about optimal results, or the "fidelity" obtainable with an AVR in any configuration. We're talking about the number of amplifiers (amplifier channels) are being used on each speaker cabinet. If you're using two amplifier channels per cabinet...it's bi-amped. The sonics may be horrible--or fabulous--depending on the quality of the equipment used.
    For that matter, how would you define a stereo amplifier that had a dual-wound transformer? Separate filter caps, separate secondary windings, SHARED IRON, AND SHARED PRIMARY WINDING including the single power cord. Far as I know, there's no legal definition of "Dual Mono"; industry standards would seem to allow a stereo amp with a dual-wound transformer but separate filter caps per channel to be labeled "Dual Mono" implying "separate" power supplies.
  • delkal
    delkal Posts: 764
    I think everyone is getting way too caught up that the OP is even thinking about using an AVR for two channel (Gasp and OMG!!!!). Not everyone can spend thousands on a dedicated system and you use what you have in the real world. And a big plus to them that they are thinking about experimenting some on a quest to improve the sound.
    Think of your first system and the comments you would get if you were a new poster and posted about it. Gasp and OMG!!!! again.
    I can see where this discussion can have some merit. Self proclaimed "Audiophiles" or not I bet just about all of the regulars here also own a AV setup........With a dreaded AVR!. So can we improve the sound?
    This is the same question as the OP's, just worded differently. I also think everyone else with an AVR can relate..........I have a biwired center channel speaker. Right now it is hooked up to the AVR center channel with a single wire (and even the crappy brass jumper). I also have 2 extra channels that are not being used. Can I improve the sound by plugging half of the speaker into an unused channel?
    F1nut Posts: 51,721
    No as you are robbing Peter to pay Paul. The more channels you use in an AVR the less wpc it will be able to provide. Why is that? It's because of the single power supply.
  • delkal
    delkal Posts: 764
    What are your thoughts of biwiring a speaker. Does it improve the sound? And since everyone has been splitting hairs lately I mean 2 separate wires from the same channel on an amp to the high and low of a speaker with passive crossovers.
    How about swapping the brass jumper on those passive crossover speakers with the $14,000 jumper that company was selling?
    A number of posters here think these changes improve if not "transform" your system to a new level..........But it is impossible to hear any difference when hooking up the same speaker to 2 different channels of an AVR?
  • rpf65
    rpf65 Posts: 2,127
    something like this would be a better choice than two separate wires:
    https://www.thecableco.com/theater-4-speaker-cable-pair.html
    Jumpers don’t have to be expensive:
    https://www.thecableco.com/clear-oval-jumper.html
    No AVRs here -- well, actually, there are a couple, but not hooked up.
    Not much TV is watched here.
    F1nut Posts: 51,721
    delkal wrote: »
    I never said you wouldn't hear a difference, I said it wasn't bi-amping. That said, I see no advantage to sucking more power from an already over taxed power supply.
    Changing the basic stock jumpers to high quality cable jumpers is a proven improvement, so is proper bi-amping.
  • gp4jesus
    gp4jesus Posts: 2,016
    If you have the means, that is wire etc, TRY IT! For better or worse you may hear a difference. If nothing else you’ll increase wire size, something a more reactive loads tend to favor.
    This comes from a big bi-amp/tri-amp fan - see my sig.
    *all connected w/Premiere ICs
