Speaker Dust Caps
Hi All
The dust caps on my Linn's are crumbling down I will order replacements tomorrow. Now what is the best way to remove the old glue?
Cheers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
I'd take an exact-o down to where you're comfortable, then use the remaining glue as a placement guide and glue back in.
I've been very successful at razor x then just peeling the old off. (paper cone) Making sure you hold the cone so you don't pull up over the pole piece. Is the cone and cap plastic? Careful it can be very brittle and cutting very close like @FestYboy suggests might be best
