Should I connect my TV to my DAC?
  • warrenwarren Posts: 647
    How did you ever hook up all this great gear? Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • afterburntafterburnt Posts: 5,429
    warren wrote: »
    Got HDMI?
    Yeah, and I thought that I could use the ARC to get the TV signal to the Cambridge. That doesn't work and I prefer not to do that anyway. I think I have to take it in to the Geek Squad because it's only a 40". I don't want those people in my house anyway.
    "The radio is broken, it don't work no more" I don't remember what happend but it didn't work with coax or optical.
  • afterburnt wrote: »
    Haven't seen you in a while Bruce. Glad to see you're still kicking!
    afterburnt wrote: »
    Kicking and screaming all the way, I won't go quietly!
  • DSkipDSkip Posts: 15,669
    afterburnt wrote: »
    afterburnt wrote: »
    You did for a little while. Welcome back bud. I missed your antics.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • BlueBirdMusicBlueBirdMusic Registered User Posts: 487
    DSkip wrote: »
    Me Too, it's has become too sane around here!
    DSkip wrote: »
    afterburnt wrote: »
    afterburnt wrote: »
    Are you making sport of my behavioral disorder? Hmmmm
    Maybe there is a problem because thr TV output is some fancy format?
    @DSkip ehat do you think? I am thinking it is an AV codec so it wont work.
    If it won't play you should be able to convert the signal to a PCM stream that the DAC can handle. Most standalone dacs won't do Dolby or dts
    audiothesis.com/
    Cabling: Wireworld
    I bet you are right. I will figure it out evetually. I may even start watching it with decent sound.
    Solved the problem by connection the coax from my BR. I only want to use it on occasion and this is a perfect solution.
  • ClipdatClipdat Posts: 6,479
    afterburnt wrote: »
    8ayOhgx.gif?noredirect
    • "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
    afterburnt wrote: »
    The BR went weird on me after playing a data disc. I went into settings and changed it to PCM from Bitstream and it worked again. Maybe the data disc switched it to Bitstream? I switched the TV to PCM but I have to get back there and connect a cable to see it corrected the problem too. Too tired to try it now, I may get stuck back there and starve to death.
    warren wrote: »
    Hello Kitty boombox
    I just plugged everything in flushed the toilet and hit the garage door opener and voila music!
  • HzTweakerHzTweaker Posts: 518
    DSkip wrote: »
    I agree with Skip. I had same issue/sound during play back when I first hooked up my Samsung smart TV via Opt. to my little SMSL DAC. Then I switched the TV's playback to PCM and its worked ever since.
    2ch rig:
    Speakers: LSi9s
    Preamplifier: Parasound P5
    Power Amp: Parasound A23
    CDP: Denon 1520; RIP Pioneer DV-563A.
    Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB
Howdy, Stranger!
