New Polk signs for my 1.2tl's
  • My transformer and Larry's case sit un-touched as I have not had the time... not to threadjack, but does anyone have the parts list for the build of the dreadnaught?
    @nooshinjohn Have a look at my SDA Upgrade 2 thread
  • honestaquarian
    honestaquarian Posts: 3,258
    edited December 2018
    lawdogg wrote: »
    Nice! ... 1.2TLs, 1.2kW per channel ... don't tell me you have a 1.2L Mitsubishi Mirage outside o:)
    Yugo 3cyl. :p
    Oh it's far worse than that.........my little old 2cyl 2 liter (2000cc) Vulcan shares the room with the Macs
    Hey does this cause problems with early reflections thereby destroying the SDA imaging???? ;):p
  • motorstereo
    motorstereo Posts: 2,359
    ^^^^Yes indeed it does. I move it outside when it's time to sit down and do some serious listening.
    audioluvr Posts: 5,982
    If you have the A/L tranny and case you have pretty much everything you need except the Neutrik air tight connectors and your choice of speaker wire. Here's my build link which has a slug of useful pics and links from "the gang"...
    https://forum.polkaudio.com/discussion/179914/dreadnaught-build-question/p1
