What to fill audio rack legs with?
Is there an advantage to using one medium over another when it comes to filling the upright tubes of an audio rack? I'm guessing no unless one is considerably cheaper than others? The 2 that come to mind for me are sand and bb's(such as in shotgun shells).
Yep, my name really is Bob.
  • afterburnt
    afterburnt Posts: 7,892
    My guess is using both would be optimal. The shot will provide mass and the sand will fill the voids thus stabilizing the shot. Just don't use a shotgun to fill you rack with lead, the sand will leak out.
  • delkal
    delkal Posts: 764
    edited December 2018
    Sand.....$5.00 (with a lot left over)
    Lead shot....$50 for a 25 lb bag (and you will probably need more)
    Will you hear a difference?............Doubtful.
    If you do go with lead you don't want to use BBs. Use 9 shot. The small shot they use for skeet shooting.
    Post edited by delkal on
  • verb
    verb Posts: 10,176
    Price aside, when comparing the densities (Kg/cubic meter) of the 2 materials:
    Lead = 11,343
    Sand = 1522
    So lead is nearly 7.5 times heavier than sand! Sure the grain size of the lead shot is bigger, so the pack density of the sand filled tubes would be greater, but in the end you'll get the most mass loading if lead shot is used. FWIW, of course.
    F1nut Posts: 51,760
    You'd likely want use a mix of sand and lead shot as filling them completely with shot would be expensive. Also, using all shot would make the rack extremely heavy, maybe too heavy for its own good.
