What to fill audio rack legs with?
muncybob
Is there an advantage to using one medium over another when it comes to filling the upright tubes of an audio rack? I'm guessing no unless one is considerably cheaper than others? The 2 that come to mind for me are sand and bb's(such as in shotgun shells).
Yep, my name really is Bob.
My guess is using both would be optimal. The shot will provide mass and the sand will fill the voids thus stabilizing the shot. Just don't use a shotgun to fill you rack with lead, the sand will leak out.
Sand.....$5.00 (with a lot left over)
Lead shot....$50 for a 25 lb bag (and you will probably need more)
Will you hear a difference?............Doubtful.
If you do go with lead you don't want to use BBs. Use 9 shot. The small shot they use for skeet shooting.Post edited by delkal on -
Price aside, when comparing the densities (Kg/cubic meter) of the 2 materials:
Lead = 11,343
Sand = 1522
So lead is nearly 7.5 times heavier than sand! Sure the grain size of the lead shot is bigger, so the pack density of the sand filled tubes would be greater, but in the end you'll get the most mass loading if lead shot is used. FWIW, of course.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
You'd likely want use a mix of sand and lead shot as filling them completely with shot would be expensive. Also, using all shot would make the rack extremely heavy, maybe too heavy for its own good.Political Correctness'.........defined
