McCormack DNA-125 Stereo Power Amp - No longer for sale
halo
McCormack DNA-125 stereo power amplifier. This amp has been modded by Bob Backert of RHB Sound Dezign with upgraded signal path caps (Black Gate) and power supply. Cost of the mod was $500.00 alone. This is, bar none, the best sounding amp I have ever owned. The amp looks good except for a few blemishes here and there. Nothing big or really noticeable but I'm being overly cautious in my description just in case you see something I miss. Rear lettering has aged in a few places. The amp performs and sounds amazing. Original box & packing materials included. Local pick up is welcome and encouraged. I will ship at buyer's expense.
Price is $1000 to Polk Forum members in good standing with at least 100 posts. Price is $1200 to anyone else.
That is one sweet amp!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Nice amp..Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
Almost 150 looks and no takers ? C'mon guys, for the price it doesn't get much better for an amp of this quality.HT SYSTEM-
lsi 9's -
Bad timing for me.
Got a Mccormack singing away while reading this.
Hard to beat for this price"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Bad timing here too
Just picked up more power too -
If I was in a different situation, I'd be all over this. That and...if I had your money, I'd burn mine.HT SYSTEM-
lsi 9's -
BumpAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
How would this compare to a DNA .5?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
DNA 0.5 is older.
Specs:
Output Power: 100 watts per channel into 8 ohms, and 200 watts per channel into 4 ohms, both channels driven from 20 Hz to 20 kHz at less than 1% THD.
Output Current: 25 Amps peak, per channel
Input Impedance: 100 Kohm
Input Sensitivity: .850 Vrms
Voltage Gain: 30 dB
Frequency Response: - 3dB @ .5 Hz, 200 kHz Signal-to-Noise: 100 dB
Harmonic Distortion (1 KHz, 8 ohm load): .05% Signal Polarity ("Absolute Phase"): Non-Inverting Power Requirements: .65 Amps / 80 Watts @ Idle
3.2 Amps/ 400 Watts @ Clipping (8 ohms) 117 VAC / 60 Hz
Dimensions: 19" W x 5 7/8" H x 15" D Shipping Weight: 30 lbs
DNA-125 is newer and this is modded by Bob Backert.
Stock Specifications:
Power: 125 watts per channel at less than 1.0% THD or IMD, both channels driven into 8 ohms from 20 Hz to 20 kHz. 200 watts per channel into 4 ohms.
Input Impedance: 100 kOhms
Input Sensitivity: 1 volt rms
Hum and Noise: better than 98 dB below rated power
Dimensions: 5.125" H x 16" D x 19" W
Weight: 37 lbs.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Damn I want this. Terrible timing though, I’m in the middle of moving, and will have to move again 6 months after this one, so the stereo is on the back burner for awhile. I’m sure you will be able to get rid of it pretty easily2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
stangman67 wrote: »Damn I want this. Terrible timing though, I’m in the middle of moving, and will have to move again 6 months after this one, so the stereo is on the back burner for awhile. I’m sure you will be able to get rid of it pretty easily
No longer for saleAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
