Parasound NewClassic 2250
Milito
What is your opinion of this amp and what would you pay for one that is 8 years old?
It looks to be in very good condition and is located about 30 minutes from me.
I'm thinking about trying to get it to pair with my Yamaha 2070 for 2 channel listening.
I personally do not care for the Classic series. Much prefer the HCA series for 2 channel.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
I might agree with Motor above. Really all depends on the sound your looking for. The Classic series will have a bit more detailed sound , maybe a tad more sterile over the HCA series. HCA is more musical to my ears, a tad on the warmer side of neutral. Halo series is big on detail retrieval, but also lacks some musicality to my ears.
With Polk speakers, the HCA series works well. It's not the cutest kid on the block, but sounds more musical with Polk speakers to these ears.HT SYSTEM-
lsi 9's -
Thanks for the feedback, it sounds like I need to continue to look for a HCA1500 or a B&K Reference 200.2.
Halo is out of my budget at this time.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
The B&k will be a touch smoother on the top end. If I had to choose between the 2, I might tip the scale to the B&k. That's not putting down the HCA either, it's a fine amp on it's own no doubt.HT SYSTEM-
lsi 9's -
I had one powering my lsim 703's and I loved it.
Yep, add B&K to your list.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
An HCA-1200 series two would also offer plenty of power for your speakers, just to expand the possibilities a bit.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
