Parasound NewClassic 2250
Milito
Milito Posts: 2,003
edited December 2018 in Electronics
What is your opinion of this amp and what would you pay for one that is 8 years old?
It looks to be in very good condition and is located about 30 minutes from me.
I'm thinking about trying to get it to pair with my Yamaha 2070 for 2 channel listening.
  • motorhead43026
    I personally do not care for the Classic series. Much prefer the HCA series for 2 channel.
    I might agree with Motor above. Really all depends on the sound your looking for. The Classic series will have a bit more detailed sound , maybe a tad more sterile over the HCA series. HCA is more musical to my ears, a tad on the warmer side of neutral. Halo series is big on detail retrieval, but also lacks some musicality to my ears.
    With Polk speakers, the HCA series works well. It's not the cutest kid on the block, but sounds more musical with Polk speakers to these ears.
  • Milito
    Milito Posts: 2,003
    Thanks for the feedback, it sounds like I need to continue to look for a HCA1500 or a B&K Reference 200.2.
    Halo is out of my budget at this time.
    The B&k will be a touch smoother on the top end. If I had to choose between the 2, I might tip the scale to the B&k. That's not putting down the HCA either, it's a fine amp on it's own no doubt.
  • sgtmick63
    I had one powering my lsim 703's and I loved it.
  • motorhead43026
    Yep, add B&K to your list.
  • rooftop59
    rooftop59 Posts: 8,120
    Milito wrote: »
    An HCA-1200 series two would also offer plenty of power for your speakers, just to expand the possibilities a bit.
    Game Room 5.1.4:
    Bedroom 2.1
