Not for the faint of heart.
joecoulson
That was my daily grind for 3 years. Easy with the proper tools.
Having never did it before myself, when I refurbed my Kenwood TT, I made new headshell leads in about 30 minutes and used the same tonearm cable. The results are a vast improvement over my stock leads and tonearm cable.
You'll be fine! I have faith. **Note: This comment should not be misconstrued as any endorsement of any religion or spiritual affirmation.**"Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Lol!!
Knee deep now
joecoulson wrote: »Lol!!
Knee deep now
Your red wire flange kanibbler is 14 degrees out of sync with phase flapper......
FYI.... -
Knee deep now
FYI....
no worries he gonna save it with a jolt of 240v -
This spliced together crap was what was inside my tonearm, I can only imagine I’m going to hear an improvement.
You are a braver man than me....
Ok. I throw in the towel. Paul tried to help me but I’m done. I got 15 years out of it. That should be good.
joecoulson wrote: »Ok. I throw in the towel. Paul tried to help me but I’m done. I got 15 years out of it. That should be good.
Never give up Joe my man! Patience grasshopper.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I don't even know what I'm looking at here.
mdaudioguy wrote: »I don't even know what I'm looking at here.
A Tonearm! AFAIK!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
A Tonearm! AFAIK!
Yeah, I caught that much, but what's in the first pic and what's being given a shot? -
Sorry sir no condescension meant!
I believe Joe may be trying to re-wire the tonearm output wires to a new set of RCA cables, with a separate jack to the TT. Just my guess.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yeah so I can say I tried. I think it was out of my skill set. The table just had this ground loop somewhere in the tonearm. Paul helped me check all wires and continuity but I could not isolate it.
I got a good run from this deck but it’s going out to pasture.
New deck on the way. -
Turntables are notorious for ground loops. Of course, they are based on 19th century technology.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Not quite Mr. Fox... the concept may be that old, but the technology has not remained stagnant. The basic precepts that current tech has evolved from came about in the late 1950's.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
I’m already up and running. Rega P2 and mounted the Nagaoka Mp110 on it. Guess I should have just done this to begin with. Sounds fantastic
Should I start a new thread? -
joecoulson wrote: »I’m already up and running. Rega P2 and mounted the Nagaoka Mp110 on it. Guess I should have just done this to begin with. Sounds fantastic
It's your thread do as you wish -
Ok. Here it is
