SRS 2 (2x Blade) vs 2.3 TL. Any real listening experiences?
Hi All,
Long time monitor 7 owner, turned to a recent SRS 2 (stock) owner. Simply blown away at the awesomeness of these speakers. Now that I'm hooked (like many of you) I'm wondering if I can make the experience any better. I've compared my blade/blade SRS 2's to my Genelec 8050's and they hold up well, so I'm confident all of the components are still working well. I'm not into fixing things that ain't broke. So not looking to start replacing components. That said, I've spotted some 2.3TL's for sale and wondering of they would be a significant improvement.
I'm NOT bothered by the 13k bump of the SL2000's (maybe I'm deaf up there) but I do feel the clarity and definition of the speakers could be a little better. When reading about the SL 2000 vs SL 3000 it seems the only info offered is in regards to the more natural flat response curve of the newer tweeter. But nothing in regards to overall performance.
My question is this. Has anyone done a head to head comparison of these speakers in stock setup? Do the original driver changes, crossover updates and tweeter differences make a significant difference that it is worth purchasing the TL's (assuming they are in perfect working order as well)? Again, I'm not looking at this point in time to change to the RD tweeters and replace crossover components if all is working as they were originally intended, so please don't comment as such, I'm aware of the options.
Just looking for a real world listening comparison between generations, STOCK setup.
thanks much!
    nooshinjohn Posts: 26,001
    edited November 2018
    Your speakers are not performing as intended. Sound deteriorates as capacitors and other components age. All of the clarity and definition you seem to be missing would be corrected by performing the crossover upgrades and RDO tweeter swaps. These upgrades did not happen just for the heck of it. They will take your enjoyment of these speakers to another level, and restore the details lost to the effects of aged components.
    pitdogg2 Posts: 27,325
    what is your power source?
  • I'm using a Yamaha MX800 amp, RME UFX as a firewire pre into my laptop streaming Tidal - HiFi and Master quality material. Also have loads of 96/24 bit material thru iTunes playback.
  • @nooshinjohn - I hear you. Part of my thinking with the 2.3TL's is that should I decide the upgrade the path to the 198's is simpler. I believe it's been said the 198's are better than the 194's?
  • I should add that I'm not missing clarity and definition - I'm actually amazed at the clarity of the reverb I can hear in the recordings, the spatial-ness and depth and noise heard in the background of recordings. I just wonder if a touch more is available. Is that why they speakers were updated at that time.
    I am a musician and recording engineer, I know what real instruments sounds like. I know what amazing speakers sounds like - I've worked on the best of the best. I've always loved the Polk sound from when I was a teen (now 48) and wonder if getting the last gen will be any different.
    Both are fine speakers but the 2.3tl is definitely the more musical speaker IMO. They can be upgraded for a little less coin and can be used with non-common ground amps and monobloc amps with a transformer or the AI-1 cable. SRS2 blade/blade cannot at all be used with mono's or non common ground amps. The 4th and 5th gen SDA was the cream of the crop so to speak.
    F1nut Posts: 52,005
    The 2.3TL is the better speaker.
  • Conradicles
    Conradicles Posts: 6,377
    I have had both, but not compared them in the same room. Both great speakers.
    The 2.3TL is hard to beat.
    gudnoyez Posts: 8,174
    I have heard from many forum members here, and other forums that the 2.3tl's were considered the cream of the crop.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Have owned both pair at the same time, the 2's are actually a little tougher load as the 2.3's are a little more efficient. I'm working on another pair of 2.3TL's now, they are definely the better of the two models. Get them, you can't have too many SDA's laying around ;)
  • thanks all for the responses. I'm supposed to pick them up tomorrow. If they check out, I'll report back on my comparison of the two.
  • Mike Reeter
    No peeker here :D But I would like to check out your Museum some time!
