JM Lab Focal Mini Utopia Single Center Mono Channel WBT Posts
VR3
Great center channel!!
Great condition JM Lab (Focal) Mini Utopia. Bottom shows normal wear for a monitor loudspeaker. The bottom is in good enough shape to place speaker on side for an awesome center channel!
The bottom woofer was missing a phase plug and was inoperable. This was shipped to Focal France, they replaced the phase plug with the newest factory spec and repaired the woofer for proper operation. The new phase plug is aluminum versus resin filled plastic. This can be painted if you so desire!
Sound is excellent! The last Utopia speaker generation with a user serviceable tweeter!
Included in the photos are the most obvious blemishes on the speakers, I would say it is a solid 7 out of 10, from a distance you would not notice any of the blemishes.
I do not have the original box but I have shipped speakers for close to 2 decades with no issues. You will not be disappointed.
$1000 + Shipping + Paypal
Dimensions -
24"T x ’16"D x 10"W
Weight
59 pounds
Original MSRP 3500 each
Drivers
6.5" Focal woofers "W Sandwich"
1" Tioxid inverted tweeter
Specs
Ported through slots in the front
50Hz to 25kHz +/- 3dB
91.5dB (2.83V/1M)
8 ohm nom
25 to 150Wpc
Point to point crossovers (stock)
Lead plate damped enclosure
WBT Binding Posts
Anigré side panels
Tauri wood panel for tweeter accents
Link to review: http://www.soundstage.com/revequip/jmlab_mini_utopia.htm
Dimensions -
24"T x ’16"D x 10"W
Weight
59 pounds
Drivers
Specs
91.5dB (2.83V/1M)
8 ohm nom
25 to 150Wpc
WBT Binding Posts
Anigré side panels
In the right section bump
Haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I wish!
Is it me or do all those inductors go completely against what we have learned recently
Ivan actually learned something would be the bigger question
Imo, if the crossover was designed in that orientation, doesn't matter. If you were to change the orientation with the same values you would actually change the specs, if that makes sense- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Agree Trey although way above my skill set. (as Ron so eloquently points put
If all that was planned into the circuit then yes it plays a critical role.
JM Labs is no Cerwin Vega, JM Labs/Focal certainly know how to build top tier gear no question about that.
GLWTS -
Shameless bump- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'm still wishing. I asked Santa to bring.
I'm pulling this particular one as I have two more coming but I will relist something similar for only 650 plus shipping (approx $75)
Not sure you can find a better center channel than that- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
