WTB: MW4850/1 for CS350
Fudai
I have a CS350 center speaker with one frozen driver (I am thinking magnet shift d/t moving recently). Looking for a replacement.
Thanks,
Fudai
Thanks,
Fudai
If it is magnet shift, it can be repaired fairly easily. Put in an alert on the Bay if you insist on a "new" driver. Might find a whole 350 for a good price...
Thanks. I worry that I’m not savvy enough to fix it. I’d need some detailed instructions on the repair and how to build the jig...
Those drivers come up often in ebay. The complete center as well comes up often for good prices 75-100. Get one and have several spares. Drivers tend to sell for 40-45 bucks.... see where I'm going here?
Keep an eye out for LSfx's as well. They use the same drivers.
Thanks for the LSFX tip!
Be warned, they're usually pricey...
LSfx's, older model. Not Lsifx. Think I paid like $75 for mine. -
There’s a single white one on eBay right now... bidding is at ~$15
That's 2 drivers and 2 tweets. Get it! -
ken brydson wrote: »
Good catch. -
Interesting do you have a link as it is not coming up on any search i just did?
I do see a pair for 99.00 -
Will these drivers do for my CS350?
The only difference is the ones in the 350 will probably have bucking magnets which are not needed anymore unless you are still running a CRT TV.
