SDA CRS+ and normal speakers at the same time?
Gretsch6136
Hi all,
Just wondering if I connect my SDA's to Speaker output A (and use the interconnecting SDA cable) can I also run another set of normal speakers off the B output in another room?
Just a little concerned that the interconnecting cable might cause issues when running both sets at the same time. I don't want to risk blowing anything up!
The amp is a Denon PMA-715RG
Thanks,
Mark
Thanks,
Mark
Running SDA's off the A and another conventional pair off the B would not be an issue in itself, however the CRS+ is a nominal 6 ohm load. Your integrated is rated as follows, A+B: 8ohm-16ohm meaning the nominal load of both pairs should not be less than 8 ohms. I would advise not doing what you've inquired about.Political Correctness'.........defined
President of Club Polk -
Thanks F1nut. I would rarely run them at the same time, and if so, at low volumes. Thanks for your input mate!
