ModWright OPPO UDP-205
Toolfan66
Well it’s here, unfortunately I won’t really have time to spend with it till this weekend but here are some pics,
Post edited by Toolfan66 on
Power Supply
That is a sweet looking 205... look forward to your impressions.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Ok curiosity has grabbed a hold of me..
I wonder who makes their film caps?
That is some good looking stuff Larry. -
They are built by specs by Dan. Each are measured to meet spec before installed.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
VERY NICE!!
thanks Ron. -
I wondered the same thing about the caps when I popped the hood, it is all very well done and built, I don’t see where any one thing was sacrificed for the sake of saving a buck..
Thanks Ron!!
I've only heard positive things about Modwright work and their attention to detail.
Nice! Congrats and enjoy!
Dan's tube regulated power supply is well designed and uses quality components. Clean power. I used upgraded tubes in the PS.
I've owned his SWP 9.0SE, Sony 999ES with tube reg PS, Sony 9100ES with tube reg PS and his SWLP 9.0SE with Blue face, tube reg PS and built in phono. I had one issue with a PS which he corrected quickly.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Very nice! Looking forward to hear your review.
Dang! Very very nice
Sweet! Enjoy!
Way nice! Congrats!Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears
Thanks Guys!!!! Can't wait to set it up...
And it’s supposed to only get better after 200 hours??? I can’t freakin wait!!!
Talk about taking it to a whole new level, I have that feeling again like I did when I just got started in this hobby, it’s been a long time since I have felt this way.. -
You make loving fun, one of my favorite discs... -
Does the modification eliminate multi-channel analog out?
Do these particular mods only affect the audio performance?
Or does the video get improved as well? -
Where's the blue goop?Political Correctness'.........defined
President of Club Polk -
honestaquarian wrote: »Do these particular mods only affect the audio performance?
Audio only, 2 channel side...Where's the blue goop?
Blue goop?? I know nothing of blue goop..
lsi 9's -
Ok, someone fill me in...
Edit: a little search and I caught on.. LOL!!! I never saw that thread, glad Dan dosen't do work like that.. -
I’m curious if you ever let the stock 205 fully run -in prior to sending to Dan...
. . I just hooked mine up and it’s bright and harsh, but smoooothing out slowly ....
Did you get the full Monty? ie MW balls-to-the-walls treatment?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
The first one I purchased yes I did, the second one I purchased that I was lucky to get during their last runs is the one I sent to ModWright, no I did not let it fully run, but it now has about 100hrs on it, and still sounds fantastic..
I did everything but the region free upgrade, I will never use it....
Also I figure I can apply my own blue goop, and hockey tape for better sound...
Don't forget to cover every square millimeter of the inside with a green Sharpie, just to be safe.
Your right, I dont
