ModWright OPPO UDP-205
Toolfan66
Toolfan66 Posts: 18,284
edited October 2018 in Electronics
Well it’s here, unfortunately I won’t really have time to spend with it till this weekend but here are some pics,
Post edited by Toolfan66 on
    nooshinjohn Posts: 26,058
    That is a sweet looking 205... look forward to your impressions.
    pitdogg2 Posts: 27,540
    Ok curiosity has grabbed a hold of me..
    I wonder who makes their film caps?
    That is some good looking stuff Larry.
    txcoastal1 Posts: 13,519
    They are built by specs by Dan. Each are measured to meet spec before installed.
    VERY NICE!!
    thanks Ron.
    I wondered the same thing about the caps when I popped the hood, it is all very well done and built, I don’t see where any one thing was sacrificed for the sake of saving a buck..
  • Emlyn
    Emlyn Posts: 4,864
    I've only heard positive things about Modwright work and their attention to detail.
    SCompRacer Posts: 9,147
    edited October 2018
    Nice! Congrats and enjoy!
    Dan's tube regulated power supply is well designed and uses quality components. Clean power. I used upgraded tubes in the PS.
    I've owned his SWP 9.0SE, Sony 999ES with tube reg PS, Sony 9100ES with tube reg PS and his SWLP 9.0SE with Blue face, tube reg PS and built in phono. I had one issue with a PS which he corrected quickly.
  • gmcman
    gmcman Posts: 1,864
    Very nice! Looking forward to hear your review.
  • dromunds
    dromunds Posts: 10,159
    Dang! Very very nice
  • SIHAB
    SIHAB Posts: 5,668
    Way nice! Congrats!
    Thanks Guys!!!! Can't wait to set it up...
    edited October 2018
    And it’s supposed to only get better after 200 hours??? I can’t freakin wait!!!
    Talk about taking it to a whole new level, I have that feeling again like I did when I just got started in this hobby, it’s been a long time since I have felt this way..
    You make loving fun, one of my favorite discs...
  • afterburnt
    afterburnt Posts: 7,892
    Does the modification eliminate multi-channel analog out?
    afterburnt wrote: »
    No..
  • Do these particular mods only affect the audio performance?
    Or does the video get improved as well?
    F1nut Posts: 52,139
    Where's the blue goop?
    Audio only, 2 channel side...
    Blue goop?? I know nothing of blue goop..
    EndersShadow Posts: 17,740
    Or the black RFI tape :wink:
    edited November 2018
    Ok, someone fill me in... :#
    Edit: a little search and I caught on.. LOL!!! I never saw that thread, glad Dan dosen't do work like that..
  • GlennDog
    GlennDog Posts: 3,158
    I’m curious if you ever let the stock 205 fully run -in prior to sending to Dan...
    . . I just hooked mine up and it’s bright and harsh, but smoooothing out slowly ....
    Did you get the full Monty? ie MW balls-to-the-walls treatment?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    The first one I purchased yes I did, the second one I purchased that I was lucky to get during their last runs is the one I sent to ModWright, no I did not let it fully run, but it now has about 100hrs on it, and still sounds fantastic..
    I did everything but the region free upgrade, I will never use it....
    Also I figure I can apply my own blue goop, and hockey tape for better sound... :wink:
    Viking64 Posts: 7,696
    Toolfan66 wrote: »
    Don't forget to cover every square millimeter of the inside with a green Sharpie, just to be safe. :p
    Toolfan66 wrote: »
    Your right, I dont :wink:
