Shameless Plug !!!!!!!!!
gimpod
Upgrade your 4th & 5th Gen SDA boards and crossovers Here.
Check with David (@westmassguy) at DHS Speaker Service.
Tony does some excellent work! Great boards!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Nothing to be shameful of here. You provide this community with a great service and product.
ExactlyPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Tony
your boards are so special to use SDA lovers that it need to be out in the open so others can see how much better these are then trying to cram all those newer caps into a smaller board that you have to first un-soldered to use again!
The newer better caps are just so much bigger now that these boards are AWESOME!!!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thank you guys!
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
And, too add, we’re glad you’re back!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Tony's boards are top notch. Buy them for your 4th or 5th gen. SDA's without hesitation. I used them in my 2B's, 3.1TL's, and 2.3TL's, and would use them again without hesitation.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
BEST NON-POLK PRODUCT EVER!!!!
are they ok for gen 1 SRS's?Tony's boards are top notch. Buy them for your 4th or 5th gen. SDA's without hesitation. I used them in my 2B's, 3.1TL's, and 2.3TL's, and would use them again without hesitation.
The_Polkster wrote: »are they ok for gen 1 SRS's?
NO 4th & 5th Gen Single Board Style SDA/SDA SRS ie.. SDA 2B/CRS+/TL MOD (1987+), SDA 1C, SDA SRS 2 (1987 Pin/Blade I.C.), SDA SRS 3.1TL, SDA SRS 2.3, SDA SRS 2.3TL, SDA SRS 1.2, SDA SRS 1.2TL.
And yes I know bad timing.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
No shame in that game
Sadly, my newest project pair are 1Bs, so will have to play Tetris with the caps when that time comes."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
