Paradigm Reference Studio 20 V2 REAL CHERRY WOOD
Selling a beautiful pair of Paradigm Reference Studio 20 V2 speakers with Cherry wood side panels
Incredible full range sound from a stand mount speaker! Rich, lucious bass, midrange and highs
Local pick up only Mechanicsburg, PA
Asking $425
Studio 20 v2 Specifications
Design
2-driver, 2-way bookshelf / stand-mounted
Crossover
3rd order electro/acoustic at 1.5kHz
Frequency Response On-Axis
±2dB from 54 Hz - 22 kHz
Frequency Response 30° Off-Axis
±2dB from 54 Hz - 20 kHz
High Frequency Driver
25mm (1 in) PAL™ pure-aluminum dome, diecast heatsink chassis, ferro-fluid cooled
Mid/Bass Frequency Driver
170mm (6-3/4 in), MLP™ mica-polymer cone, AVS™ diecast heatsink chassis, 38mm voice-coil
Low Frequency Extension
38Hz (DIN)
Sensitivity Room / Anechoic
89 dB / 86 dB
Impedance
Compatible with 8 ohms
Suitable Amplifier Power Range
15 - 150 watts
Maximum Input Power
100 watts
Weight
50 lbs. (23 kg)
Dimensions HxWxD
14.5" × 8.75" × 11.375"
(36.8cm × 22.2cm × 28.9cm)
