Odd Layout Request
ydnarb
ydnarb Posts: 16
I am just trying to purchase a home theater setup but I have a layout problem.
My 50 inch plasma is on an island wall with no way to run wires to my rear or side walls. (no basement).
On a 5.1 is it feasible to put all speakers in the front or does this just make a mess??
Any other options.
pe
Post edited by ydnarb on
  • McLoki
    McLoki Posts: 5,231
    edited December 2004
    Any chance we could get a wide angle picture or drawing of your setup? I am sure someone here will come up with something....
    (ranch house? can you go up and run though the ceiling?)
    Michael
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Hi, and welcome to the forum.
    If your room is carpeted, you may be able to place flat profile wiring under the carpet. The rears could be placed on floor stands. Obviously, you're not going to get a surround sound with everything up front.
    Mike
  • ydnarb
    ydnarb Posts: 16
    Thanks for the help so far.
    The room is about 20 feet long by 12 feet wide.
    Unfortunately the island has no ceiling access and the carpeting is already down and wall to wall. Part of my problem is that I might be relocating in the next few months or I guess I could just rip up the carpet and place the flat cable in place.
    I am trying to come up wih something that makes sense for a big improvement over the panasonic plasma speakers and maybe something I can build on when I move.
    As I mentioned the island is free standing in the exact center of the 20 foot long side of the rectangular side of the wall. The island is about 9 feet wide and the 50 inch plasma leaves about 2 feet on each side of wall space.
    Can't get to the ceiling. No basement. Makes a great setup for the plasma but I forgot that the speaker wires would be a problem.
    Should I just go simple and pick up a Bose accoustimas 5 type setup?
    Thanks again for the suggestions
    pe
  • ydnarb
    ydnarb Posts: 16
    Thanks BlueMD......Can i just spin around every once in awhile to get the sensation of the speakers from the front wall!!!!??
    pe
  • McLoki
    McLoki Posts: 5,231
    You could put a small hole in the wall behind your speakers and another hole just above the baseboard. Run your speaker wire through the hole. Then run it under the baseboard around to your AVR. (you should only see the wire as it crosses the baseboard.) I have used this method in apartments and with a minimum of spackling, you can get things back to normal when you are ready to move out.
    Michael
  • ydnarb
    ydnarb Posts: 16
    Thanks again. There is no baseboard anywhere once it gets to the edge of the island. It is really just a free standing island that separates the living room from a dining and kitchen area.
    Picture just a 9 foot wide wall with openings left and right and the island does not go to the ceiling.
    To make matters worse the sides of the island are tiled and there is no carpet going to the sides.
    open ************** open
    TV ISLAND
    pe
  • BlueMDPicker
    Michael
    I think the island wall has him screwed on getting back to the AVR via the baseboard. An electricians fishtape could be worked under the carpet only requiring the carpet to be pulled up from the tack strip at both ends. Or, he can just go with the spinning chair idea.
  • McLoki
    McLoki Posts: 5,231
    have you thought about a nice set of wireless headphones?
    :D
    Michael
  • ydnarb
    ydnarb Posts: 16
    Are the systems any good with just front two or three speakers plus a subwoofer???
    The chair doesn't spin by the way......only me!!!!!
    pe
  • ydnarb
    ydnarb Posts: 16
    Now that you mention it...will wireless rear speaker systems work for me?????
    pe
    VR3 Posts: 29,409
    get thin strips of wood, a finish nailer - cut them bout 1" wide each, and run this and nail them together to make a L shape along the edge of the wall (paint it the color of your wall if you want) and put your wire under it...
    This way, if you move or w/e - you just lift it up, easy access. Looks good, hides the wire...
    As for going up the wall...
    HD or Lowes sells corner pieces that dont attach all the way to the corner...well you can figure out the rest
    For more ideas/projects - check this out
    http://www.cableorganizer.com/home-theater/
  • McLoki
    McLoki Posts: 5,231
    I would think so. I don't really know of any I can recommend though....
    VR3 Posts: 29,409
    wireless speakers suck
  • McLoki
    McLoki Posts: 5,231
    That may be true, but for HT it should work. (as rears only). SACD may blow, but where you just want some surround, it can't be much worse than the 6600 surrounds I am currently using. (roll off at 150hz)
  • ydnarb
    ydnarb Posts: 16
    Wireless is now out based on your decisive response!!!!
    Headphones might work as it will drown out my wife!!!!
    We are now getting somewhere.
    What about three speaker plus subwoofer systems in just the front.
    Oh for the good old days with the RCA 27 inch tv and a single speaker!!!!
    pe
    VR3 Posts: 29,409
    I'd rather go without surrounds...imo
    3 speakers will do, you can even try front surrounds - will give off a nice 'ambience'
    Would need a SPL meter, of course
  • ydnarb
    ydnarb Posts: 16
    What do you mean by "front surrounds"? With a subwoofer also?
    I have a good receiver but nowhere to hook it to. That is why I was thinking of just the Bose or Polk fronts and a subwoofer system of some sort.
    Are the "Niro" units any good??
    Thanks again
    PE
    pe
    VR3 Posts: 29,409
    Bascially instead of mounting ur surrounds in the back, mount them in the front...
  • ydnarb
    ydnarb Posts: 16
    Thanks VR.... That was really my original question but response from others was rather cool to say the least. Have you tried this?
    The good thing about it if it works is the simplicity and I can easily pull it apart when I relocate shortly.
    I can also wait I suppose but I am basically an impatient person and want to do something now to improve from the basics on the plasma
    pe
    VR3 Posts: 29,409
    LoL,
    Must say that I have...
    Keep in mind, my room is 10.5x10.5x8 - hehe
    The front surrounds are better than no surrounds for movies, IMO... gives off a nice 'ambience'
  • ydnarb
    ydnarb Posts: 16
    Do you use a powered subwoofer also????
    All speakers at same height?
    Spaced high / low??
    Inside and outside front??
    Thanks again.
    pe
    VR3 Posts: 29,409
    http://www.eandr.biz/Vr3_HT_Pictures_HT.html
    Take a look for yourself, Im to lazy to type
    And you would put the surrounds higher than the mains, by 3 feet or so
  • ydnarb
    ydnarb Posts: 16
    You must vibrate within that "headphone"!!!!
    Thanks for your help. Sounds like my best, simple approach as long as I keep the speakers small (that is one of the many penances I have to pay for being married!!!!), except for the subwoofer.
    The worst that can happen is I have a powerfull "murky" sound coming from in front of me I guess.
    PE
    pe
    VR3 Posts: 29,409
    Check out Polks RM system and a SVS subwoofer...
  • TheReaper
    TheReaper Posts: 636
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • ntculenuff
    ntculenuff Posts: 1,146
    since the room is carpet you could put a small hole in the carpet behind your system run spkr wire through the crawl space and pop it up through a small hole where you are placing each of your rears. this way you have essentially no visible wire mess and when you leave you can just pull the wire back through and just rub your hand over the carpet where the hole is and the hole is covered.
    just another thought to add to the many:)
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • ydnarb
    ydnarb Posts: 16
    There is no crawlspace either. It is a concrete floor under the carpeting.
    Also my wife would not appreciate a cord cover/runner across the living room for the other suggestion.
    This "island" is a real island with no place to go up, down or sideways.
    Thanks Phil
    pe
    VR3 Posts: 29,409
    I think you need some His & Her headphones...
    Wireless headphones, at that...
  • ydnarb
    ydnarb Posts: 16
    Might be my last resort.
    One set of noise deadening headphones might be the fix for everything!!!!
    pe
  • jarros
    jarros Posts: 84
    If you're thinking about getting headphones, why not just set up all five channels at the front (or even 3 channels, front L+R and Center)? Using a pair of wireless headphones will only give you stereo sound, so you'd be getting more of a surround sound effect even using 3 channels. Add surrounds on stands that are higher than your front channels, and you're a big step above headphones. That way more people can listen if you want to have a few friends over.
    HT Setup:
    Pioneer VSX-D912K
    Polk CSi30 Center
    RM6005 Satellites (Fronts/Surrounds/Rear Center)
    Nameless 10" Sub
