Seeking Help Identifying My Speakers
Polkaudioforumname
I recently picked up a pair of RTA 12(?) speakers from a local business closing up shop. I had no intentions of buying speakers but when they were offered for $20 I jumped on them but I really have no idea of what I bought.
The serial numbers are 12 09119 and 12 09037. I read that the speakers are channel specific but there is nothing on the speakers to Identify right from left. An email from Polk said colored dots were used but the speakers have no colored dots. The email from Polk is also what led me to here.
I've also read here that different tweeters were used but there are no names on the tweeters to identify the manufacturer. All that is on them is an ink stamped number on the magnet. They are rather unremarkable and bland in appearance.
Finally, one of the plastic corners on a crossover cover is broken. Are they still available? Also missing is the angled stand. Can anyone tell me what angle they were at and what was the height of the angle the speaker sat in on in the stand? The cover cloth is also faded. Are replacements available?
Thank you.
A new Polk Audio speaker owner.
Thank you.
Pictures are worth a thousand words.Political Correctness'.........defined
President of Club Polk -
I can't directly download pictures on this computer but they look like these from eBay. They don't have the "block" around the tweeters as some do.
If yours look exactly like those with tweeter mounted vertically they are the original RTA 12. The tweeter is a Peerless.Political Correctness'.........defined
Thank you F1nut. Do these speakers have the right, left side phasing requirement? If so, how do I tell one side from the other?
They do, should have a mark or label on the back. If not you'll have try them on each side to hear which way sounds best.Political Correctness'.........defined
Yup, that's what Polk said. There are no marks. My ears are shot after years of loud noises so I can't guarantee what I'm hearing. This is more about just getting it right. Seems odd though that Polk puts nothing on their speakers but serial numbers but can't give you and information about a speaker based on the serial number. To my ability though, I like how they sound.
Thank you for your help.
Those speakers are close to 40 years old, so you really can't expect them to have info based on serial numbers. On top of that, Polk didn't sell matched pairs and that's why your serial numbers are not consecutive.Political Correctness'.........defined
I don't expect anything by the serial number. I do expect more than nothing though. Hell, the only way a speaker can be identified is to know them by sight or go look at pictures to find a best match. I have never seen speakers with less information on them except maybe the cheapest, no name brand imports like my first stereo, Electrophonic from K-Mart in the 60's.
Oh and BTW, there were no stands for them, angled or otherwise offered from Polk.
$20 was an absolute steal, nice grab! -
As I already told you, they would have come with a channel label on the back panel. They either came off or someone removed them.
In the pic you can see the channel labels and if you look closely you can see a red dot on the inductors.
Interesting, so the dot gives you left and right? How is that for forward thinking back in the day.
I don't see any red dots on my 12B's but they are labeled L and R on the crossover. Could be from a previous owner, I dunno....
This is the E-Mail I received from Polk:
Hello,
For the RTA 12, we used to mark them with avery dots; we used green for left and blue for right. Unfortunately, there are no other visually identifiers or whether they are left or right speakers.
If you set the speakers up next to each other, you should be able to hear the difference between the left and right. Take the grilles off and listen to the individual speakers. When next to each other correctly, the outside speakers will produce just bass, and the inside speakers will produce bass and midrange.
Tom Carter
Customer Service Technician
My speakers have no dots, stickers or former owner notations.
The speakers sound fantastic and nothing can take away from that. I do question why upper end speakers don't come with a permanent mark to identify right from left. We're not talking about a vast economic hit for doing so. -
Sounds pretty plain and simple to me. Then after mark them yourself.
Sounds like they gave a viable solution to identify which is which...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
As I said, I can't tell the difference due to hearing loss. This is more about getting it right for the sake of getting it right and for others. Some speakers are almost painful, especially over time, to listen to. These aren't. I can't argue with your comments but really, wouldn't a permanent identification be better than contacting the manufacturer about their intentions?
You should be able to trace the XO and identify the low freq driver through to the 3 pin connector, then it's a matter of pulling a driver and continuing the trace.
Dude, they came with channel stickers on them as evidenced by the pic I posted. How was Polk supposed to know that 40 years down the road they would either fall off or that someone would remove them!?!
Following your logic Polk should have also bolted down the top hats you're missing and secured them with Loctite, so they wouldn't get lost because the speakers were voiced with them in place.Post edited by F1nut onPolitical Correctness'.........defined
Now this I understand. Thank you.Dude, they came with channel stickers on them as evidenced by the pic I posted. How was Polk supposed to know that 40 years down the road they would either fall off or that someone would remove them!?!
?? Missing top hats? I'm not missing anything. On one speaker the plastic corner post is broken but nothing is missing. Not sure where you concluded this. I understand and accept your determined defense of Polk's practice. "Fall off or removed," exactly! You have identified the shortcoming of the practice.
You said, "They don't have the "block" around the tweeters as some do.", which I took to mean the top hats, but evidently you meant something else. Sorry.
I can only surmise you don't have much experience with vintage speakers as there's a boat load of them out there that are missing some or all of their original label. To call it a shortcoming is.......well, ignorant.
After you determine which channel is which please attach a permanent engraved metal plaque to each speaker. Heck, you might even consider starting a business providing plaques for all of the vintage speakers out there missing their original paper labels.
Experience with vintage speakers? You're right, no. Experience with vintage and antique autos and planes, loads of experience. It's rare to deal with symmetric and more than likely asymmetric parts that aren't marked R and L. The first really good set of speakers I owned were Infinity Reference Speakers. I guess they were ignorant and wasting time and money for marking their speakers. Same goes for Quad Speakers.
Maybe Polk thought stickers were fine because they never believed their speakers would last that long? I don't believe that and I would have never gone there except you seem stuck on the notion that if someone disagrees with you, that's not enough. How far are you willing to go with demeaning someone in belief that you are right and they are not only wrong but ignorant and god knows what else? Sad. -
Most Polk speakers still have them. The problem is when they are stored in humidity, or someone takes them off, etc.
Polkaudioforumname wrote: »Experience with vintage speakers? You're right, no. Experience with vintage and antique autos and planes, loads of experience. It's rare to deal with symmetric and more than likely asymmetric parts that aren't marked R and L. The first really good set of speakers I owned were Infinity Reference Speakers. I guess they were ignorant and wasting time and money for marking their speakers. Same goes for Quad Speakers.
What's sad is your non-stop harping about a $20.00 pair of speakers missing their paper label, then after being told how to figure out the issue state that your hearing is so shot you wouldn't be able to perform the task........LOLPolitical Correctness'.........defined
The original 12 did not have cascaded crossovers so location shouldn’t matter. This is one reason that later models are more desirable.
Well, that's interesting. I admit I've never looked at the schematic for that speaker. Perhaps they did the same as the older Model/Monitor 11 and put a sheet of acoustic foam under one of the mid-drivers to limit the frequency response. If so, the OP should be able to tell by simply removing the drivers and taking a look.
Even if that's the case, the Model/Monitor 11 was still marked Left and Right with a paper label.Political Correctness'.........defined
DSkip,
Thank you. Answers one of my earlier questions if it even matters with these speakers because there was nothing to identify right from left. Unfortunately something else that was lost in nonsense.
C4Political Correctness'.........defined
ahh, the percussive option.
I have no clue about what was asked with the phone but are taggants coming with phone numbers on them now too?
