Yama P2201 I switched it on heard a thump speakers blown
Dont worry the speakers were only Beovox S30.
The loud thump was not bassy but more of a midrange sound.
What is wrong with this Yamaha P2201 and how do I fix it?
Answers
    tonyb Posts: 33,072
    Might be best to tell us first how you hooked everything up.
  • Hooked up everything the normal way as usual
  • motorstereo
    motorstereo Posts: 2,342
    I don't believe there's a speaker relay on that model. Use a multimeter and check for dc voltage at the speaker terminals.
  • verb
    verb Posts: 10,176
    edited October 2018
    Hey great title to this thread! I had to chuckle when I first read it. Sorry for your loss! :smile:
    Seriously we need more details. We’re here to help.
  • Which details do you need?
    mhardy6647 Posts: 35,014
    Check for DC on the outputs. A bad driver or output transistor could be passing all or part of one of the DC "rail" voltages straight to your speakers, with catastrophic results.
    The other, very real possibility, that comes to my mind is that there's a severe, but transient, imbalance in the power supply at turn-on that results in a very low frequency (or DC) voltage before the amp stabilizes. Many solid state amplifiers have relays to protect the speakers from such things, but yours apparently does not. In such cases, speakers make excellent fuses (unfortunately).
  • How do i check dc voltage? Its time I learned how to use a multi meter....
    edited October 2018
    g7trader wrote: »
    http://audiokarma.org/forums/index.php?threads/amplifier-distortion-dc-offset-and-you.5634/
    No signal applied to amp, no speakers connected, amp output to speaker terminals "on".
    Measure for DC voltage across each channel's output terminals. Red lead of DMM to positive terminal, black to negative. Value should be very close to zero volts (see the AK sticky for info).
    tonyb Posts: 33,072
    Take it to a qualified repair shop. Get an estimate, then decide if it's worth fixing or used as a boat anchor.
    tonyb wrote: »
    This is the best answer of all.
  • tonyb wrote: »
    He said £70 but I rather fix it myself.
    I fix all speakers a Beogram 4002 and a few other repairs by luck.
    My Dad found two dead capacitors probably using a multimeter but he is psycho and has bad communication skills he used tippex and wrote all over the amp 'don't use will kill speakers'
    If anyone wants to see photos instagram same username.
    edited October 2018
    "Haven't used a DMM" + "fix it myself" =
    Spend the 70 quid & get it properly repaired and calibrated. The P2201 is probably a worthwhile investment for repair.
    tonyb Posts: 33,072
    Spend the coin, fixing the amp, or spend more coin fixing the speakers. Your call.
  • motorstereo
    Even if you fix what's broken it's still an amp with no dc protection and still capable of ruining speakers or worse yet starting a fire. I say chalk it up to experience and use this as excuse to find a better amp.....preferably one that isn't a fire hazard.
    tonyb Posts: 33,072
    Now what fun would that be ? :)
    Hook it up to a Monoprice amp in unison and you may have created your own particle smasher.
  • This is the best there is better sounding than my Pioneer SA-9500, Rotel RX802 and Philips black tulip
  • codycatalist
    codycatalist Posts: 2,662
    The early Adcom GFA series don't have relays either. I like to live dangerously.
    ... like the ol' Flame Linears.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    g7trader wrote: »
    Ah, so you sell Hi-End Audio Equipment on eBay...
  • FestYboy
    FestYboy Posts: 3,861
    g7trader wrote: »
    Lives in England, doesn't speak English... Or at least can't construct a proper sentence.
    Loving the idea that his repairs are done with luck... :|
