RCA Cables
I've just built new speaker cables and jumpers using 12 ga OFC and Sewell Strike banana plugs. I really like these plugs, by the way. Very easy to install and they have great contact with the wire. But that's off topic. I want to upgrade my RCA cables and I've found some reasonably priced interconnects with both solid cores and some with wire strand cores. Can I get some opinions from the gallery about which is the better alternative? My thinking is the strand wire is probably best but I'm no Electrical Engineer.
Answers
    pitdogg2 Posts: 24,585
    edited September 2018
    Both are used in the real world. your preference to be honest. Audioquest built their business on solid wire. Most others use a small stranded wire, some others use different wire diameters within the same jacket.
  • [Deleted User]
    Has there been any testing that would indicate one's better than the other?
  • gmcman
    gmcman Posts: 1,759
    Most of the RCA cables I've used have been pretty much a larger single center conductor, or maybe a couple small conductors...but I can't say I've seen many that have a number of fine strands for the center conductor.
    Really depends on your gear as well. The more revealing your system is, the more you are likely going to hear the difference.
    What is your budget and how many cables are you looking for?
  • mlistens03
    mlistens03 Posts: 2,767
    All the generic IC's I've seen have tiny, tiny strands of wire, although those are generic, and that's not what we are talking about.
  • [Deleted User]
    gmcman wrote: »
    I was looking at ugreen cables and they seem like a good value. My budget is really not an issue but I don't see much value in esoteric cables.
    Audioquest Evergreen?
  • [Deleted User]
    These cables from ugreen are the ones i was looking into. They seem to have a good size wire strand core and seem to be decent build quality at a good price. I'm considering Fospower as well, which use a solid core. If i did this right, these images show the differences.
    I'd throw those away.
    tonyb Posts: 32,906
    I'd use them to tie up my Tomato plants....but for audio, umm....no.
  • [Deleted User]
    Can't really toss them because i haven't bought them. :wink:
    I'm not one of those guys that thinks a cable adds all that much to a sound system. I think a cheap set of connectors or cables will keep a system from sounding its best but if you gave me two cables with the same materials and construction and said cable 'A' sounds better because it was blessed by the Pope, i'd have to question that. What I'm looking for is opinions on which is the better material: multi-strand or solid core. It sounds like no one can prove one is better than the other. My gut tells me the multi-strand is possibly going to be better simply because speaker cables are multi-strand.
    Am I off-base?
  • DaveHo
    DaveHo Posts: 3,481
    Since it appears you are not looking to go crazy on the cost: Blues Jeans LC-1 cables. Quality materials, solid construction.
    bluejeanscable.com/
  • DaveHo
    DaveHo Posts: 3,481
    ...My gut tells me the multi-strand is possibly going to be better simply because speaker cables are multi-strand.
    Am I off-base?
    Yes, you are focusing on just one tiny part of cable construction. Cable geometry, insulation materials, connector quality/construction all play an important role too.
    Am I off-base?
    way off base
    You came here asking us to tell you which is best..... WHY? use your own ears to make that determination. Those are cheaply built cables nothing more nothing less. Cables CAN and DO add much to your system as a whole this is something you have already dismissed. yet then go on to say that cheap cables can keep a system from sounding its best. Which is it? can't have it both ways.
    Go buy some very good used cables Audioquest, Kimber, MIT and a multitude of others come to mind.
    As I said I would not waste a dime on the cable you have a picture of. There are many many better quality cables out there to be had.
  • [Deleted User]
    I don't think you understand. I'm ONLY asking if solid core or multi-strand is better. The pictures were for reference.
  • gmcman
    gmcman Posts: 1,759
    I'm not trying to take what you stated out of context...but here's my best approach...
    You are looking for opinions, as well as possibly proving one over the other.
    My opinion, yes, cables sound different, sometimes better, sometimes worse. I've experienced it, many, many others have as well. It wasn't placebo, I could hear things with one cable that I couldn't with another. What I could hear is more natural detail and not just a "sound".
    Again, this was dependent on the rest of the gear. My first CD player and my first pro-logic receiver, did not really care too much about cables. When I dove into seperate components like a higher quality CD player, preamp, amp, then the cables came more into play.
    What happens with electrical signals with different types of cables can be measured.
    Here's a good read:
    https://www.belden.com/blog/broadcast/understanding-skin-effect-and-frequency
    As far as solid vs. stranded....tough call. Seems solid is more favorable, and when using stranded, a "Litz" type which coats each individual strand helps dramatically.
    I have recently re-wired my speakers with litz wire, which is stranded, replacing non-coated stranded and the difference was substantial...night and day difference.
    However, this is comparing 29 year-old stranded wire with stranded wire having a much higher quality surface as well as being coated. Night and day difference.
    So this concludes that better cables can sound better.
    The cable debate goes on and on, deep into the archives of many forums. You will likely find that interconnects will use both but like Dskip mentioned, is based on the total construction...again, it's a science. You will have to experiment with your gear.
    Speaker cables can be both, but seems the majority of the higher end cables use solid core rather than stranded.
    To be frank, don't go by your gut. If you want to try the stranded vs. solid speaker cable...then may I suggest try a cheap stranded speaker cable..like some Monster XP on a spool, then try some Audioquest Type-4.
    You can be the judge.
  • joecoulson
    joecoulson Posts: 4,943
    Yup. Night and day
    I just made that exact swap (monster to type 4) and just dayum.
    Your question sounds to me like this:
    Which is better? A V8 or a V6 engine.
    Umm in what context? Are they both equal displacement, aispiration, weight, same chassis, same drivetrain etc.
    maybe I am off base, but asking about a construction type of cable as to make a decision which is better is just like asking that question above, which actually the answer is V8...
    tonyb Posts: 32,906
    Bluejeans-Signal Cable-Audioquest, 3 companies you should be looking at.
  • DaveHo
    DaveHo Posts: 3,481
    It's not that simple. There is no definitive answer to that question for all the reasons already listed.
  • CoolJazz
    Since you keep trying to reduce the scope to just half the signal path, lets go to one thing that hasn't been mentioned yet.
    Solid is a design for wire that's not moved around, stranded for flexibility and being moved around. That said, I've always found myself drawn to the sound of the solid conductor wire...but I'm not a habitual "fiddler" that can't leave things alone.
    You've mentioned for some reason "proving" which sounds better but also ask for opinions. Then seem to reject the opinions given. I'm not sure that encourages people to offer up much discussion.
    Proving is tough since the connection is dependent on what's it's hooked to and everyone here has different systems obviously. The wire can't and doesn't perform on it's own in a vacuum. It also doesn't work by just "sending" a signal through the one wire, it's actually a current loop interconnecting systems and with unbalanced, sharing paths. Without taking the time to understand it's a "system" you are listening to, and rejecting all advice that you've asked for, you are almost certain to miss the mark with any purchase.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
  • [Deleted User]
    This is a little frustrating for me guys, because I'm not disagreeing with anyone. I don't think once in all these exchanges i said i think anyone is wrong in their opinion. I just want to know what opinions people have about the type of interconnect is best, not the brand. It's like asking if tube amps are better than solid state, and if you have an opinion, why? Instead i'm hearing from some that if you buy this or that brand you're making a mistake.
    Please don't take any of this personally. I'm a relatively data driven guy and I'm skeptical of hype so I continue to ask for information until I'm satisfied. It annoys the crap out of my Wife, believe me.
    So, anyway, I did some more searching on the web and I found this site which turns my thinking upside down.
    www.tnt-audio.com/clinica/intere.html
    Basically this guy is a proponent for high quality, solid core interconnects for this reason. Below is a quote from this site.
    To strand, or not to strand - that is the question here
    (from Cabelitis, a very avantguard play - spoken by the Hero - the Son of an audio-cablemaker)
    As we already mentioned second order effects, lets have a look at some other relevant ones.
    In my experience all stranded Cables where each single conductor is made from several strands of copper that are not insulated from each other imparts an unpleasant harshness and brightness to the sound.
    There are a few theories why this is so, if you want to read one of the more nutcake flavored ones, it comes from Ben Duncan. He proposes that copper-oxide forms between the strands that encourages non-linear conduction (little "mV" Diodes).
    I shall keep out of this (there are pages full of letters on this in Wireless World), but as said I prefer solid conductors over stranded ones.
    Litz-Style cables where each conductor is insulated from the others are usually much better or we can use single strands of solid core wire.
    There is an argument that rectangular thin but wide conductors improve at the frequency extremes. Short of using Foil Tapes, one can use a few thin and round conductors (say 42 Gauge Magnet wire) run parallel, similar to the style of Cables from Nordost.
    One more second order effect is the interaction of the signal current (as small as it is) with the shield. This will induce eddy currents in the shield that again will degrade the sound. Plenty of spacing helps but again, it reduces the effectiveness of the shielding.
    So, I think I have my answer after all. I'll look for decent quality solid core interconnects at a price that I'm comfortable with. Thanks to everyone for offering suggestions.
    well then Anti-cables should be your choice they have all kinds of data on their cables.
    No matter how much data you have it cannot replace your ears and the gear in front of those cables....
  • [Deleted User]
    Well, from what i understand Anti-cables have 100% signal loss so that is not an option for me.
    F1nut Posts: 49,806
    While I don't care for their sound, if they had a 100% signal loss there would be no sound.....hello!
  • kharp1
    kharp1 Posts: 3,453
    In defense of those that have said "don't buy that cable" they are saying that out of experience...trying to save you money. This is something that will have to be proven to you by your own trial and error. You seem to have some preconceived notions, yet, state that you're asking for people's experience. As previously mentioned, you can't have it both ways. Pick a jumping off point and experiment. Decide for yourself.
    As also previously mentioned your gear will also play a big role. A receiver and BR player from a department store may not respond to cable changes.
  • [Deleted User]
    DSkip wrote: »
    I think his comment was tongue in cheek, not referring to the brand itself.
    exactly. In my mind I am HILARIOUS.
  • [Deleted User]
    I did look at Anti-cables and it looks like a very attractive option. I see they're solid core and it sounds like most people prefer that type of cable.
    F1nut Posts: 49,806
    Keep looking and btw, there is no such model as a Polk SDA SRS 1.
  • [Deleted User]
    I've decided on cables from WireWorld. They look like good quality and they're multi-strand cores with decent shielding. I didn't hear much compelling evidence that solid or strand was better sooo, I went with strand for the added flexibility. Thanks for the input.
    Hi Mom. I changed my equipment list to SRS. :p
