Man Cave Mini-HT Project
13»
  • Mikey081057
    Mikey081057 Posts: 7,127
    Made a few tweaks today.
    Almost there... Cable management next weekend. SVS SB2000 is excellent complement to the Ushers.
    Garage | Polk Monitor 5B's
    txcoastal1 Posts: 13,124
    Where did the tubes go?
  • Mikey081057
    Tubes got moved... they weren't connected to this rig anyhow and i added my second a23 to power the surrounds.
  • Mikey081057
    edited April 2017
    Did some cable management and changed out the blinds to darken the room for movies. Tweaked the harmony remote a bit. Still have a few cables to change out but a big improvement. The Usher front end sounds awesome with the HT bypass setup and still allows 2 channel sources to connect directly to the P5 taking the HT AVR out of the signal path.
  • Mikey081057
    edited September 2018
    Been over a year since I updated this thread but this rig has had some improvements since April '17
    Mytek Brooklyn DAC+
    HP Slice Elite SS Computer
    SVS SB4000 Sub
    Marantz AV 7704 AV Pre
    TeraDaK Linear PS
    APC UPS
    I guess I'm gonna be putting some stuff up 4 sale soon.
    I think the Parasound P5 will prolly be going as most certainly the Marantz SR5011 AVR will go... Might make some changes to the Parsound Amps as well Ideally a 3 or 5 channel amp would really help with some of the excessive rack requirements.
    Still got some cable management to do (the hard part). Might get some J channel cable management stuff.
  • So the good news is that my incoming UPS ground shipment from Mass. is not getting delayed and will be delivered on schedule tomorrow (Tuesday)... it is heavy @69 lbs.and that will be followed by another heavy (*ish) package coming from SVS on Thursday (ish).
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Getting an Outlaw? Aren’t they in Mass?
  • Nope
  • mrbiron
    mrbiron Posts: 5,711
    He bought me... ;)
    I ate a bunch of prunes before the initial boxing. You'll wanna let me air out, for a bit, upon arrival.
  • Depends
  • Yueck.
  • OK so here is the UNVEIL
    A new Parasound A52+ to go with the New Marantz AV7704 PrePro...
    The A52+ will power the Center and the 4 surrounds and the A21 will power the mains in a 7.1 setip.
    The A52+ sure is pretty and not quite as bulky as the A21.
    I've eliminated the P5 and the A23's and have a new pair of SVS Ultra Surround speakers that will close this project out... Still have some buttoning up to do but everything is connected and warming up....do some testing and run Audessy...
    Almost Done...
    SCompRacer Posts: 8,350
    Get yourself some plastic spacers and zip ties to hold wiring to the holes in metal sheets.
  • Nice Work.....
  • Loooove the Black and Gold
  • It's the Pittsburgh Steelers of amplifiers.... very workman like and comes from a family of champions.
    I did some tweaking/setting up the AV7704 stuff....
    Right now listening to some SACD's with the UDP 203 as the source. For as much as I listen to CD/SACD I think I can live with the Oppo as a source.
    I have the Mytek DAC+ as a 2 channel source into the AV7704 with the HDMI video joined together so I can use the ROON client with a remote KYBD/touchpad to listen to streaming music. Actually have it so that when in this mode it turns off the 5 channel A52+ and uses the A21 only for 2 channel listening.
    I guess I can also set up another input to watch video from the computer HDMI too.
    After all this stuff in configged I'll then setup the Logitech remote to select them all.
    Getting there.... Alot of options getting set up here....
  • All amp connections between the Pre Pro and amps are using balanced interconnects. Makes it Vewy Vewy quiet....
  • Mikey081057
    Today I installed a pair of SVS Ultra Surround speakers in "Duet" mode whereas each speaker has a rear surround channel and a surround back channel. This is a small room and cabling and installing individual surround and surround back speakers is impractical. Each of these speakers has dual crossovers and dual sets of binding posts and make this possible. I mounted them on the wall up above ear level as the guide suggests and ran Audessy. The mounting system is the best I've seen/used. I will test with the new Jurassic World 4K ultra later.
    Like all SVS products the piano black is beautifully done.
    Here is the description from the SVS site.
    https://www.svsound.com/products/ultra-surround
  • Some pix
    Time to break 'em in :p
  • Been letting the system air out a little these past couple of evenings.... Spent some time with the Logitech Harmony 950 remote and programmed it for:
    Watch TV
    Watch Blu Ray
    Listen to CD (SA8004)
    Play Game (PS4)
    Listen to Streaming Music (DAC)
    The logitech harmony's are ok.... a little buggy setup software but after you mess with it a bit you can get most things to work.
  • steveinaz
    steveinaz Posts: 19,521
    Very cool cave! I haven't done anything yet (audio-wise) in my shop. I still need to dig out my Pioneer SX-780, and I *think* I'm gonna score some Elac bookies for the shop. We need to have a post-move garage sale so I can free up some space for a good sized gun safe in there.
  • I have to say that the SVS *speakers* are as well made as their subs....
