Can't figure it out but didn't want to get "too" crazy".
codycatalist
So let me paint a picture.
Car: 09 Corolla
Amps: 4 Channel class D, 2 Channel class D bridged to 4ohm subwoofer
Wiring: 8g power wire (x2) running through bolt down fuses (60A for the 4 channel and 80A for the 2 channel). Grounds are separate and screwed to the chassis in the trunk, paint scraped off for better conductivity. RCAs ran on opposing sides of car to trunk.
Sub: Polk 12inch MM SVC
Issue: For the last couple months I have had an odd noise coming from the subwoofer. It sounds like white noise with popping here and there, sometimes it is there sometimes it goes away (can post video if it helps). I immediately though of a grounding issue as I removed the RCAs from the 2 channel amp and the noise remained. I moved the ground 3 times to no avail.
Looked at the power wires leading from the battery and the 2 channel had a highly oxidized wire, I mean this wire looked grey instead of copper so I cut it off and reseated it properly. That did not change the issue and it remained. I don't want to rip the whole install out and redo it all however I have a feeling this is wiring related.
I did not do the initial install, it was done by a reputable installation center local to my area. If it was my call I would have ran a 4g power and ground to distribution blocks then 8g out to my components as I feel there is less points of failure.
Car: 09 Corolla
What's to say the 2 ch amp hasn't failed? Have you checked the board for corrosion?
Same with car running or not?My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »Same with car running or not?
Indeed. Could be the amp but my experience points me to that being the last ditch component that has gone out.
I have been just living with it, not too concerned about the sub getting smoked. I'll just buy a new one. Im apprehensive to pull the install out as I'm not "graceful" with car parts. See this wasnt an issue on my cars as I didn't care but this is the other half's vehicle.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Sounds like amp failure to me.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Where is the amp grounded?
I would check that before I threw away the amp.
I've found through my many, many years with car stereos that people will ground stuff, poorly, in the worst places.Expert Moron Extraordinaire
Yeah ground was my thought initially as well. I have it grounded in the trunk to the chassis. I changed grounding points already, made sure to scrape paint off etc etc.jeremymarcinko wrote: »Sounds like amp failure to me.
Possibly but considering this amp is only 2 or 3 years old I don't think that's the case. Doesn't mean it isn't a component failure in the amp but it is built well enough I want to look other places first.Just a dude doing dude-ly things
Maybe there is a loose nut behind the steering wheel?
Just kidding...
Mikey081057 wrote: »Maybe there is a loose nut behind the steering wheel?
Just kidding...
I haven't ruled it out
codycatalist wrote: »Mikey081057 wrote: »Maybe there is a loose nut behind the steering wheel?
Just kidding...
good man keeping an open mind... -
A true troubleshooter!
No one is exempt from the ID10T code. Especially not this guy who looks for the remote that is in his hand.Just a dude doing dude-ly things
I wanted to find something that will run 5-600 watts RMS into 4 ohm to push the sub to it's RMS level. I might just binge on a used Kenwood KAC-7204 bridged which should bring me to where I want to be.
If the problem remains I have no choice but to rip the whole install out and do it myself...the way I want it to be.Just a dude doing dude-ly things
