Amplifier Terminal Strips
zingo
I like my new little Hafler P1000 MOSFET amp, but it has terminal strips for the speaker connections whiech is not ideal. Has anyone done a 5-way binding post swap on an amp?
Yes. Your pics are too fuzzy to get a good look, but it should be possible to do on any amp as long as there is a bit of real estate on the back panel.Political Correctness'.........defined
President of Club Polk -
could you unscrew the screws, and then screw in little add-ons for binding posts? that's the kind of thing I'm sure someone makes somewhere.
mlistens03 wrote: »could you unscrew the screws, and then screw in little add-ons for binding posts? that's the kind of thing I'm sure someone makes somewhere.
Too close to screw 4 binding post if they made such a critter. -
I've seen people fashion their own for vintage McIntosh gear.
Couldn't someone make some sort of something to space it out though?
I'll draw my idea later when I have some spare time... -
mlistens03 wrote: »
Couldn't someone make some sort of something in their spare time though?
I'll draw my idea later when I am spaced out...
^^^^ Micah, someone who is dyslexic may have read your comment this way.
That is a short just waiting to happen....
I've seen these used
https://www.parts-express.com/parts-express-gold-plated-barrier-spade-lug-connector-screw-type--095-678 -
These should work to make them banana plug compatible.
These look like they would work, at least as a temporary solution.
Now I'm tempted to grab some for my Lafayette. -
Yeah, I thought the same thing. That may be fine for a quick test, but I wouldn't put it in my rack like that. Particularly if I had a cat that liked to play hide and seek.That is a short just waiting to happen....
It looks like PE doesn't carry them anymore, so I'll look for another source, or maybe smaller spade that fit those terminals.
Thanks! I never shop on Amazon, but that's probably a huge blind spot I should clearly remove.
I'd be worried about a short set up like that, can you flip every other one over, so it is underneath?
Very cool, either way.
I was going to put an insulator between them, but flipping them every other is a great idea!
