Upgrade from RT800i to Signature Series?
Hello new to the forum and just starting to think about building out a new HT system after upgrading my 15 year Sony old plasma to a new Sony XBR65A8F.
I ordered a Sony STR-ZA810ES receiver and plan to do a 5.1.2 Atmos setup.
For my front soundstage I currently have a pair of RT800i speakers along with a CS400i center.
For surrounds I've ordered a pair of S10s
For a sub I've ordered the Polk DSW Pro660
I'm still undecided on height speakers and not sure what my best options are.
I'm wondering if its worth the upgrade to go to the S60s and S30 from the RT/CS setup I currently have.
I'm also debating returning the sub and going with an SVS PB2000 after reading so many good reviews about it.
Thoughts?
Thoughts?
I think that the Signatures would best you RT800i's, so I'd grab those.
The SVS is the better subwoofer, but that's not to say that the DSW Pro660 is bad. The Polk sub is nice and compact, and still sounds good, but if you have the space and money, go for the SVS.
I would also recommend getting separate amplifiers for at least your mains, and the center, too. I'll let others chime in on a amplifier. -
I would wait on new Signature speakers till you see how you like the new receiver with the RTs that you have.
I also think that your receiver will be underpowered to try to handle front heights.
Everyone that has the Signatures seems happy with them, so it's probably not a bad move, but for Home Theater the RT series is very good as well, imo. -
Welcome to Club Polk Langer!
I have the Signature S60s and they are terrific, they have Polk's signature sound, look great, and are an excellent all round speaker for both music and movies.
I upgraded from a pair of 27 year old Polk RTA-8Ts, and I'm extremely happy with them. Here is my review of them from last year.
http://forum.polkaudio.com/discussion/176622/review-of-polk-signature-series-s60-speakers/p1
Bottom line, I think you would be very happy with a complete Signature system.
I also agree with getting an SVS sub.
One thing I noticed is your Sony doesn't have preouts. They cost more money, but a receiver that has preouts gives you the capability of adding separate amplification later on, which will allow your speakers to operate to their full potential. If you are able to change one out from the Sony now, rather than having to buy a new one later. Just something to consider.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks for the input mlistens03 and Jimbo18. I'll be testing out my old speakers first before ordering anything just to see how it sounds.
It, sounds like the common theme here is my receiver is going to be underpowered for this setup. For some additional details I have a 15x15 room with an 8 foot ceiling that is also open to the kitchen area on one side which is about 12x20
I'm not really sold on the idea of having a separate processor\amp(s) for the setup it is really worth going that route or would a more powerful receiver be a better\simpler option? Is there an amp and or receiver setup you would recommend?
Marantz receivers are pretty popular on here. Here is one with preouts, that you could add a separate amp to. https://www.amazon.com/Marantz-SR5012-Channel-Surround-Receiver/dp/B072ZJ9SRM/ref=sr_1_4?ie=UTF8&qid=1536071610&sr=8-4&keywords=marantz+sr6012
For amps, we are also very partial to Parasound amps, but there are others that we like as well.
Are you willing to consider used products? You can get even more for your money that way.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The denon avr-x series is also excellent, as is the Yamaha rx-a aventage series. I would look at the least expensive model with preouts so long as it has the other features you are looking at.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Thanks that Marantz looks good I may go that route. Yes I'm willing to consider used if there is enough value in it.Marantz receivers are pretty popular on here. Here is one with preouts, that you could add a separate amp to. https://www.amazon.com/Marantz-SR5012-Channel-Surround-Receiver/dp/B072ZJ9SRM/ref=sr_1_4?ie=UTF8&qid=1536071610&sr=8-4&keywords=marantz+sr6012
Keep watching the forum. Often when the Signature Series is heavily discounted, someone will post a link to it. There have been some crazy good prices on it recently.
Oh, and welcome to the forum. -
Here is a 3 channel Parasound that will wake up your front stage nicely!
https://www.audiogon.com/listings/lis93799-parasound-hca-2003a-220w-x-3-channel-amp-multi-channel-amps
Or here is a 5 channel for all of your speakers.
https://www.audiogon.com/listings/lis9348b-parasound-5250-classic-multi-channel-amps
And here is a 2 channel amp.
https://www.audiogon.com/listings/lis93341-parasound-2250-solid-stateMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Awesome thanks for pointing me in the right direction for used! So a question if I go with a receiver like the Marantz mentioned above and then attach an amp to it for the some/all of the channels will the Audyssey speaker calibration still work?Here is a 3 channel Parasound that will wake up your front stage nicely!
https://www.audiogon.com/listings/lis93341-parasound-2250-solid-state -
Yes, it will work just fine.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
If the Audyssey calibration system is anything like my Yamaha's YPAO, then yes, it'll still calibrate your system.
Audyssey Is measuring the sound that comes out of your speakers, not what leaves the receiver. So it will just take measurements of your speakers as powered by the amp. Not a problem...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Makes sense, I figured it was going to be that but wanted to be 100%.
So I ordered the Marantz 5012 and a SVS PB200 will be sending the Sony receiver back along with the Polk PSW sub.
I'm going to see how the old RT/CS sound and go from there in updating them to the Signatures,and I'll lookout for them on sale.Audyssey Is measuring the sound that comes out of your speakers, not what leaves the receiver. So it will just take measurements of your speakers as powered by the amp. Not a problem... -
Good choices. You’ll be pleased. Might find that you’re happy with the speakers...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Agreed. The 800i/400i is a no slouch combo for HT. -
There is a lot you can do, all depends on budget.
Watch Slickdeals for sales on Signatures https://www.adorama.com/pkults60g.html?sdtid=11740031&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
add sub and done.
This one has an AVR in the package and you already ordered the SR5012. That Marantz is a very nice AVR. I had no problems driving RTi8 or my current Signatures with an SR5010 but adding an amp for just my main L/R added a lot more detail.
The SVS PB2000 will shake your world nice.
Get what you have ordered setup and see how you like the sound.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
The upgrade you have coming will blow your mind. The move from your current speaks to the signatures will be a noticeable upgrade, but no where near as big. I think you might be really happy without upgrading the speakers imho...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
