WTB: Dreadnaught.
I need a dreadnaught. Used it new.
  • FestYboy
    FestYboy Posts: 3,861
    Build one... There are several threads on how to and what for.
  • Mr_Hz
    Mr_Hz Posts: 176
    Two different specs... which are you looking for? The slighly lesser spec unit is easier to obtain... toroidal xformer can be purchased directly as a stock item, while the higher audio spec version requires a group buy.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
    audioluvr Posts: 5,982
    Agreed, build your own. I built the 750 for less than $200 ish. Running mono amps and loving it!
    F1nut Posts: 51,924
    audioluvr wrote: »
    Agreed, build your own. I built the 800VA for less than $200 ish. Running mono amps and loving it!
    Fixed for ya.
    audioluvr wrote: »
    Fixed for ya.
    Oops. Thanks Jesse
