Anyone Assembled a Salamander Synergy Drawer?
RobXant
RobXant Posts: 201
edited March 2024 in Clubhouse Archives
Despite the stick-figure instructions, I am having a problem gleaning the proper orientation for the drawerfront. Salamander is closed for the night, so here I sit with my IKEA on steroids furniture.
The photo on their website is ambiguous because it shows a slightly different drawerfront than came with mine.
There is scalop that runs the length of one of the long edges, while the opposite edge has only a notch at either end.
I have it with the scallop down, to accomidate fongers reaching in from underneath to pull the drawer open. Is this right? Thanks! Rob
Yamaha RX-V1500 // Outlaw Audio M200 (x2) Panasonic TH-52PZ700U
Sony DVP-NS715P // Sony Playstation3 // Roku Soundbridge M1000[/color]
Polk LSi15 (w/Monster Z2 Wire) // Polk LSiC // Polk LSi7 // Velodyne DLS-3500
Workshop Rig: Creek 4330 // Technics SL-P310 // Cambridge Soundworks Ensemble 2
    VR3 Posts: 29,427
    edited December 2004
    pics? instruction scans? anything?
  • RobXant
    RobXant Posts: 201
    I figured it out- there is only one way it'll fit right.
    Man, this Synergy stuff is cool, but it is sooo flexible that it's a total pain in the **** to setup!
    Nearly everything is infinitely adjustable which is great once you get it in the ballpark. Downside is that once you slide a shelf/door/drawer into place, if you want to swap or add something, you must take everything out above it. It's a bit tedious, but the stuff looks and feels great. I think the trick is to sit down with a list of the gear you want to fit and then plan it out, otherwise you'll end up spending three hours on a 1 hour job (like me!).
    That was one piece, I got two more to build... Right after I get back from Starbucks! Here's the first one:
  • mantis
    mantis Posts: 17,374
    Once you build one, he next one will be alot easier. Not the easiest furniture to learn.
    I would have helped you but I just fond this thead....
    Sorry
    Dan
  • gregit
    gregit Posts: 284
    I have a Synergy unit and I love it. Very well built for a modular system.
  • HBombToo
    HBombToo Posts: 5,256
    Thats a nice looking piece of furniture. I really need a rack for the Bomb Shelter but every time I look I get so confused.
    HBomb
    ***WAREMTAE***
    VR3 Posts: 29,427
    Bomb shelter...
    Get pieces of wood and cinder blocks...
    THAT is for a bomb shelter ;)
