WTH?? PS4 Pro won't go through the receiver??
So I just picked up a PS4 Pro, and it will not go through the receiver (SC LX801) and it should, it says it cannot go through my TV main HDMI, what gives? I can hook it directly to the TV and it works fine, but part of the reason for getting the player is to play the games through the System..
I am not understanding this at all, it is 2018 is it not?? LOL!!!
  • FestYboy
    FestYboy Posts: 3,861
    Go into the tv and then feed the audio from the optical out to the rig, easy peasy. That's how I run my 4k player.
  • ^^my thoughts
  • You’re gonna need 4K HDR pass through or adjust the ps4 setting to 1080.
    I bought the ps4 pro for my son for his birthday had to adjust it to 1080, cause his tv isn’t 4K.
    Toolfan66 Posts: 18,194
    edited September 2018
    The 801 is HDR capable, nonetheless using the optical out worked.. B) thanks FYB..
    I honestly don’t remember how long ago it’s been since I used a optical cable, at least ten years I bet..
  • Alright then. Enjoy
