HELP! Needed Inductor!
Anyone know of someone who has parted out a SRS 2.3 or??? And may still have the big 16.8 mH inductor? While restoring mine my dog got ahold of my old crossover and chewed it up. Dog gone now... But speaker pops in and out. Im sure its the inductor.
Yes I've spoken to Dave. He said I'm fu... Out of luck.
Thanks all!
  • mlistens03
    mlistens03 Posts: 2,767
    Animals that eat audio gear disappear quickly...
    You could possibly get a complete XO from a parted out set on eBay.
  • FestYboy
    FestYboy Posts: 3,861
    Not all is lost. There's really no reason why you can't build one to match the other channel. The hardest part is finding the correct gauge of coated wire.
    audioluvr Posts: 5,982
    FestYboy wrote: »
    Been watching ebag since it happened. No luck yet. I may have to do the rebuild but been busy with other things so...
    pitdogg2 Posts: 27,197
    Sounds to me an easy excuse to upgrade the inductors.
    Oh ok... Ill look into a couple new Jantzen ones. Probably really expensive and on backorder but hey!
    audioluvr wrote: »
    Nope they are really reasonable. But not Jantzen. Erse 18mh then you will need to unwind some to get the value you need. I did however get all new inductors big ones like i said came from Erse all the others came from england hi-fi collective jantzen All in all pretty reasonable and all will need to be tested as sometimes they are not close to listed value so you will need to have someone do some work on them before install.
    Reach out to Dave
    https://www.hificollective.co.uk/components/inductors.html
    http://www.erseaudio.com/Products/SuperQCoils16Gauge/ESQ55-16-18000
