GEM Dandy Turntable Platter Mat
F1nut
Brand new, taken out of package and realized the label recess cut out will not work with my screw on record clamp. I paid $60.00
Your Price: $35.00
Media Mail: $3.50
Payment: PayPal
Your Price: $35.00
Media Mail: $3.50
Payment: PayPal
Are you finding that when using this on the 180gram and thicker Lp's that you have to do VTA adjustments when going from thinner to thicker Lp's?Home Theater
Not understanding label recess not working with your screw on clamp as your L.P is on the mat, do you mean that the extra 1/8 thickness leaves you with less spindle length for your clamp to clamp down on? I'm some what interested trying this on my acrylic platter.Home Theater
I never played an LP with it.Political Correctness'.........defined
President of Club Polk -
No, there's plenty of spindle sticking up. This clamping system seems to have been designed to work best with a flat platter.Post edited by F1nut onPolitical Correctness'.........defined
What kind of clamping system are you using may I ask.Home Theater
VPI screw on clamp.Political Correctness'.........defined
I'll try it Jesse. Don't have PP though. You okay with this Gudnoyez?
Ok Tom, let's see what Steve wants to do.Political Correctness'.........defined
Go for it Tom I'm thinking if I put it on my acrylic platter I think I would have to adjust the VTA for 120 gram 180 gram or 200 gram albums.Home Theater
Steve, do you adjust your VTA for those LP's now? I'm thinking not, so adding a platter mat would require adjusting the VTA for it, then playing LP's as normal.
Anyway, Tom it's yours if you want it.Political Correctness'.........defined
PM me your addy again. I'll send out a check today. Thanks.
Done, consider this SOLDPolitical Correctness'.........defined
I dont adjust with the Acrlic platter but adding another 1/8 of a inch I'm thinking you would have to make adjustments. Great deal none the less.Home Theater
Steve, like I said you would adjust the VTA after adding the mat, then play the LP's as you do now. So, if you want to try a mat you're golden.Political Correctness'.........defined
can you guys point me to some info on what you're talking about 'vta' and all that?
thx
Vertical tracking angle.
https://www.google.com/search?ie=UTF-8&source=android-browser&q=turntable+vta
