GEM Dandy Turntable Platter Mat
Brand new, taken out of package and realized the label recess cut out will not work with my screw on record clamp. I paid $60.00
Your Price: $35.00
Media Mail: $3.50
Payment: PayPal
    gudnoyez Posts: 8,166
    Are you finding that when using this on the 180gram and thicker Lp's that you have to do VTA adjustments when going from thinner to thicker Lp's?
    Not understanding label recess not working with your screw on clamp as your L.P is on the mat, do you mean that the extra 1/8 thickness leaves you with less spindle length for your clamp to clamp down on? I'm some what interested trying this on my acrylic platter.
    F1nut Posts: 51,798
    gudnoyez wrote: »
    I never played an LP with it.
    F1nut Posts: 51,798
    edited August 2018
    gudnoyez wrote: »
    No, there's plenty of spindle sticking up. This clamping system seems to have been designed to work best with a flat platter.
    Post edited by F1nut on
    What kind of clamping system are you using may I ask.
    F1nut Posts: 51,798
    VPI screw on clamp.
    treitz3 Posts: 20,014
    I'll try it Jesse. Don't have PP though. You okay with this Gudnoyez?
    F1nut Posts: 51,798
    Ok Tom, let's see what Steve wants to do.
    Go for it Tom I'm thinking if I put it on my acrylic platter I think I would have to adjust the VTA for 120 gram 180 gram or 200 gram albums.
    F1nut Posts: 51,798
    Steve, do you adjust your VTA for those LP's now? I'm thinking not, so adding a platter mat would require adjusting the VTA for it, then playing LP's as normal.
    Anyway, Tom it's yours if you want it.
    PM me your addy again. I'll send out a check today. Thanks.
    F1nut Posts: 51,798
    Done, consider this SOLD
    I dont adjust with the Acrlic platter but adding another 1/8 of a inch I'm thinking you would have to make adjustments. Great deal none the less.
    F1nut Posts: 51,798
    Steve, like I said you would adjust the VTA after adding the mat, then play the LP's as you do now. So, if you want to try a mat you're golden.
  • maingey
    maingey Posts: 632
    can you guys point me to some info on what you're talking about 'vta' and all that?
    thx
