Magnifi Mini - Red Light Flashing Non-Stop
scott1130
A couple of weeks ago I set up my Magnifi Mini. Everything worked fine. Connected it to the Google Home app at night, and it still worked fine right after connecting it. The next morning, the Mini wouldn't turn on at all. So I unplugged the unit for 20 seconds and plugged it back in. The middle light on the front of the unit started flashing red non-stop, and the unit won't respond at all. Power cycling or trying the wifi reset does nothing.
Contacted Polk support via email over 2 weeks ago, and no response. Calling isn't really an option since I work during their hours. Anybody have any ideas??
Hello,
I'll ask someone at Polk to contact you via email. -
I’m having the exact same problem! I connected my unit up last night, and couldn’t get anything but a flashing amber light this morning. If I can’t get help, I’m gonna have to take it back.
After reaching out to Polk, they replaced the unit under warranty. New unit works perfectly. Thank you, Polk!
I've been having the same issue... I turn it on, and it works for maybe 5min, then it disconnects, and I get a red blinking light and now it won't connect anymore. I've barely had it for a couple months. :-/
I had the same issue and finally found that it occurred only when I had the soundbar plugged into my Monster surge protector. I mistakenly had the soundbar plugged into one of the accessory spots which was linking it to the power for my TV. It seems like the soundbar was resetting everytime the TV was turned back on and causing the blinking red light. Not sure if this will help anyone else on this post but at least something to rule out.Post edited by Gopher80 on
After a week my unit has stopped working, just flashes a red light. Can’t get it to reset or anything.
Best place to begin is with Polk's CS at: 1-800-377-7655 and have the serial number handy.
