component class ($) compatibility
marvda1
marvda1 Posts: 4,962
edited August 2018 in Speakers
the question is, does it make sense to purchase a $16k integrated amp for a $4700 pair of speakers ?
speakers are Salk HT2-TL
http://salksound.com/model.php?model=Veracity+HT2-TL
amp is gryphon diablo 300
http://www.gryphon-audio.dk/products/integrated-amplifiers/diablo-300.aspx
a
Puritan PSM156
    nooshinjohn Posts: 25,990
    Not in my book..., but then again, I am a friggen cheapskate.
    What integrated are we talking about?
  • marvda1
    DSkip wrote: »
    Nothing about this hobby is sensible.
    I started to ask the guy but didn't want to start anything.
    Puritan PSM156
    mhardy6647 Posts: 35,203
    If the pairing is propitious, why not?
  • tratliff
    tratliff Posts: 1,809
    I think it depends on the long term plan. If it were me I would level the playing field between the two. But, if the long term plan was to upgrade speakers then it might be the right move.
    I think we all run into this from time to time when we flip components.
  • motorstereo
    motorstereo Posts: 2,359
    This is fairly close to what I have in my electronics to speakers ratio and I have no regrets. Imo if it's what you want and it doesn't break the bank then go for it as life is far too short.
    Let's go way back to [circa] 1977 -- "Randy", at Warehouse Sound in San Luis Obispo, CA (where else?) hooked a lowly Kenwood KA-3500 integrated amp (Kenwood's "entry level" amp of the time) to his big JBL monitors... let's see what happened :)
    (note the sly druggie/radio biz reference -- it was the Seventies!) ;)
    29940371068_83d9daa963_b.jpg31320and20it20cooks20text_zps4993d408 by Mark Hardy, on Flickr
    9931769165_62686928af_b.jpg313%20and%20it%20cooks by Mark Hardy, on Flickr
  • rpf65
    rpf65 Posts: 2,127
    About the only thing I would care about cost in relationship to price of other equipment is cables. I wouldn’t spend as much on speaker cables, for example, as the speakers themselves.
    That said, I wouldn’t say that an amp shouldn’t exceed 50% of the price of speakers, nor would I say 4 times the cost of speakers is too much.
    Don’t really think it should be a major factor in whatever it is you choose to buy.
    If of course you’re looking to buy that amp, for an excuse to upgrade your speakers, then I would start questioning your sanity.
    Is that you askin' Marv, or the other half ? :)
  • marvda1
    tonyb wrote: »
    I'm cheap so you know what I would do. now if they were selling the amp new for 7 or 8k I would have to think about it :o
    Puritan PSM156
  • erniejade
    erniejade Posts: 6,321
    That amp looks awesome!.
    The amp i ran for a long time was triple the price of the speakers. It had wonderful control on the speakers. I say if you have the funds to do it, why not!
  • marvda1
    turn him onto that $16k Gryphon integrated :D
    Puritan PSM156
    The only problem I see Marv, with buying an amp 3 times the price of the speaks.....
    ….is that sooner or later you'll realize the speaks need to be upgraded to match. Lucky for you, Salk has a path. Those SS8's might be calling your name in the middle of the night.
  • marvda1
    no, this is not me doing the buying.
    Puritan PSM156
  • cfrizz
    cfrizz Posts: 13,415
    If he likes it, can afford it, go for it. If the electronics boosts the performance of the speakers, or vice versa then that's a win all the way around.
    I don't pay too much attention to the various classes of things. If I like it, can afford it and am please with the results, then I'm happy, and that should be the bottom line.
    Toolfan66 Posts: 18,165
    Look what Ray is running his 1.2tl’s, I would love to be on that playing field..
