In wall enclosure needed?
dremmickdremmick Posts: 11
I bought some 265-rt for my home theater. Is there any advantage to build a backer box? Or do these speakers use whats behind the speakers as a baffle?
  • ZLTFULZLTFUL Posts: 4,877
    They are designed for use in infinite baffle but there is nothing wrong with putting in a backer box either.
    The biggest benefit and purpose of doing a backer box is to help contain the sound from entering adjacent spaces.
  • dremmickdremmick Posts: 11
    Is it worth the money and time?
    Personal preference thing really.
    If your space is open to the adjoining spaces then there really is no benefit outside of maybe a slightly tighter mid bass response.
    ZLTFUL wrote: »
    There is about a .5" gap between the exterior wall and foam board insulation. Do I want openings to adjooinging spaces.
Howdy, Stranger!
