Set-up Question
Dreamnevil
Hello All!
I have almost finished with my home theater setup consisting of the following components:
rt800i for the fronts
cs400 for the centerenter
f/x300 rear surrounds
psw350 for the sub
My question is this, what is the best choice for rear center? Do i need another cs400? Or will a cs245 or the cs175 be sufficiant?
Thanks for the input!
~Dream~:D
psw350 for the sub
~Dream~:D
Post edited by Dreamnevil on
I thing the CS245i would be fine . I have one and also have a CS400i .for surround use CS245i will do fine
You might try CC to see if they had a single open box deal on a RT25i or RT15i! Just a thought?
Oh, the bottle has been to me, my closes friend, my worse enemy! -
I like the CS245i for the rear center, too.
I'd go with the cs245i too. The cs400i would probably be unutalized overkill. Depending on usage and volume levels, any lower priced Polk might be a good choice. You might be able to use the savings towards cables or interconnects if need be.Make it Funky!
Put me down for the cs245i. It will mate well with your fx300's.
CS400 was an overkill for me! Check out my system showcase. My arrangement sounds seemless. Have Fun!:D -
OOHHHH Ya, welcome to Club Polk!!!! Really Cool web name.;)
yet another vote for the 245.
welcome to the forum...:D -
hi dreamnevil wecome to ths forum, i use a polk cs-350ls center speaker for my rear center and it works good, if you can find one used foe a good price, go for it.. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
