Set-up Question
DreamnevilDreamnevil Posts: 7
edited April 2002 in Technical/Setup
Hello All!
I have almost finished with my home theater setup consisting of the following components:
rt800i for the fronts
cs400 for the centerenter
f/x300 rear surrounds
psw350 for the sub
My question is this, what is the best choice for rear center? Do i need another cs400? Or will a cs245 or the cs175 be sufficiant?
Thanks for the input!
~Dream~:D
Post edited by Dreamnevil on
  • BBUBBABBUBBA Posts: 66
    edited April 2002
    I thing the CS245i would be fine . I have one and also have a CS400i .for surround use CS245i will do fine
  • nascarmannnascarmann Posts: 1,464
    edited April 2002
    You might try CC to see if they had a single open box deal on a RT25i or RT15i! Just a thought?smiley_idea.gif
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • OrangeToupeeOrangeToupee Posts: 488
    edited April 2002
    I like the CS245i for the rear center, too.
  • gidrahgidrah Posts: 3,031
    edited April 2002
    I'd go with the cs245i too. The cs400i would probably be unutalized overkill. Depending on usage and volume levels, any lower priced Polk might be a good choice. You might be able to use the savings towards cables or interconnects if need be.
    Make it Funky! :)
  • scottvampscottvamp Posts: 3,297
    edited April 2002
    Put me down for the cs245i. It will mate well with your fx300's.
    CS400 was an overkill for me! Check out my system showcase. My arrangement sounds seemless. Have Fun!:D
    PS3 and HD Front Projection, life is good. Too bad Blu-Ray and the PS3 are already obsolete.....:rolleyes:
    edited April 2002
    OOHHHH Ya, welcome to Club Polk!!!! Really Cool web name.;)
  • juice21juice21 Posts: 1,866
    edited April 2002
    yet another vote for the 245.
    welcome to the forum...:D
    ...the fOrce is strong with this one.
  • joe logstonjoe logston Posts: 882
    edited April 2002
    hi dreamnevil wecome to ths forum, i use a polk cs-350ls center speaker for my rear center and it works good, if you can find one used foe a good price, go for it.
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
Howdy, Stranger!
