Paradigm Reference Studio 100 v2
Selling a pair of Paradigm Reference Studio 100 V2 speakers in excellent condition.
I am the second owner of these wonderful speakers.
These are a true full range speaker, rated to 25Hz in room.
Read the rave review here: https://www.stereophile.com/floorloudspeakers/252/index.html
Asking $1000
Local pick up only, Mechanicsburg, PA
Design - 4 driver, 3-way Tower / Floorstander
Crossover - 3rd order electro/acoustic at 2.0kHz, 2nd order electro/acoustic at 250Hz
Frequency Response On-Axis - ±2dB from 39 Hz - 22 kHz
Frequency Response 30° Off-Axis - ±2dB from 39 Hz - 20 kHz
High Frequency Driver - 25mm (1 in) PAL™ pure-aluminum dome, diecast heatsink chassis, ferro-fluid cooled
Midrange Frequency Driver - 170mm (6-3/4 in), MLP™ mica-polymer cone, AVS™ diecast heatsink chassis, 38mm voice-coil
Low Frequency Driver - Two 215mm (8-1/2 in), filled polypropylene cone, AVS™ diecast heatsink chassis, 38mm voice coil
Low Frequency Extension - 25Hz (DIN)
Sensitivity Room / Anechoic - 91 dB / 88 dB
Impedance - Compatible with 8 ohms
Suitable Amplifier Power Range - 15 - 350 watts
Maximum Input Power - 210 watts
Weight - 210 lbs. (95 kg)
Dimensions HxWxD - 44.75" × 10.25" × 17.375" (113.7cm × 26.0cm × 44.1cm)
