Monoprice 50w Hybrid Amp
zingo
zingo Posts: 11,258
The reviews on these amps have been mixed, but seem to be improving as Monoprice has tweaked them over the last few years. I had eyed them out of curiosity, but never felt like spending $200 for a maybe.
But today, Monoprice emailed that the unit is currently 20% off. I went to their website to check the reviews again, and the flash page offered a 20% code. I applied it assuming it wouldn’t work, but it did! I clicked checkout and it applied free one-day shipping; with tax and one-day shipping the unit cost me $136.
I’ll try the unit out and compare it to my Denon PMA-2000, but I see a great value in a Bluetooth integrated amp for under $150 with a warranty.
https://www.monoprice.com/product?p_id=16153
«134567
  • zingo
    zingo Posts: 11,258
  • smglbrth
    smglbrth Posts: 1,506
    "Bluetooth audio for grown-ups", had to chuckle at that on their website...
  • Conradicles
    Conradicles Posts: 6,437
    Thanks for the link. I just bought one for $127.99. Can always send it back if it sounds like garbage...
  • zingo
    zingo Posts: 11,258
    It’ll sound better than a “wireless bluetooth speaker”, so that’s good enough, and might make a nice desk amp for work.
  • mark090852
    mark090852 Posts: 1,002
    I might try one out for myself for a little living room system. How are folks seeing a price lower than $159.99? That's the price I see when I add it to my cart.
    McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers.
  • Conradicles
    Use coupon code GOAL20.
  • delkal
    delkal Posts: 764
    I'm not getting any popups for another 20% off. I only see $200 minus 20% so $160. It seems like the price is variable.
    I always run an adblocker with no tracking cookies. I think that is why I'm not seeing the deals. I disabled adblocker for the monoprice site (but still have no third party tracking) but no popups. No one wants to be tracked but I think if they see you looking at all these other audio sites and amps that is when they give you a deal.
    If the reviews are good I might have to turn everything off for a while.
  • Conradicles
    You put the coupon code in at checkout.
  • Conradicles
    The coupon is on the home page.
  • mark090852
    Thanks so much for the code! I applied it at checkout and my price dropped to $127.99. Order placed.
  • delkal
    delkal Posts: 764
    Thanks. I see it now.
    Now the real dilemma........What to do at that price,
    mhardy6647 Posts: 35,562
    edited June 2018
    The 25 watt morph is... so-so.
    Manage your expectations.
  • zingo
    zingo Posts: 11,258
    edited June 2018
    I can’t find a ton of info on the 50w version as most of the info seems to be about the 25w as that was the original.
    I plan on testing it with a pair of Klipsch bookshelves and a pair of custom transmission line monitors.
    edited June 2018
    Sounds good... it'll be interesting to see what you think of it.
    Not to bias your assessment or anything :) but (FWIW) -- the 25 watt morph is kind of hard sounding, and gets kind of congested/muddled with more complicated music at moderate volume (on 104-ish dB sensitive loudpspeakers). I need to try it on some other speakers than the two I've tried so far, though. :|
    I have this urge to throw a pair of 6922s in place of the two Chinese twin triodes that are in the amp. It's not 100% clear to me that 6922s are a proper substitution -- but it looks like they might be. I really should check first and see if the filament voltage in the amp is - as was reported in early "reviews" of the 25 watt amp under another brand name - higher than 6.3 VAC. I don't really want to cook even a cheap pair of 6922s in the pursuit of knowledge.
    As a not completely unrelated aside -- I really (really) wonder whether the AF power pentode tubes in these amps* actually do anything?
    ____________________
    * The tubes in the amp (at least in the case of the 25 watt morph) are Chinese "6P15". The 6P15 is reported to be equivalent to EL86 or 6CW5.
  • zingo
    zingo Posts: 11,258
    thoughts? ;)
    My thoughts are.....plastic tables melt. :)
    Yeah -- but wooden ones burn.
    edited June 2018
    Not sure if this is a good time to mention it, but Monoprice is actually also selling a pure-play little all vacuum tube mutant variant of these "hybrid" amps. Looks to be PP EL84 (i.,e., somewhere in the 10 to 14 wpc neighborhood depending on operating points). EDIT: Monoprice website sez 10 wpc. Not nearly as cheap, though, of course, as the two hybrids.
    https://www.monoprice.com/product?c_id=109&cp_id=10919&cs_id=1091903&p_id=27222&seq=1&format=2
    PS is it just me or is that Monoprice site kind of tedious to navigate?
    Those are cute little loudspeakers.
  • zingo
    zingo Posts: 11,258
    I need to finish the cabinets, thinking glass gray paint and leaving the cherry wood horn raw, but they have been fun and sound great; the tweeter is the Vifa dual ring radiator horn loaded and the woofer is a 7" Dayton reference TL loaded.
    Well, it should be noted your operating under safer conditions than someone else I know....cough....cough.
    A fireplace right behind it makes for an easy push should things go south. :)
  • zingo
    zingo Posts: 11,258
    edited June 2018
    After an hour of listening in 24 hours, it would be hard to beat for the price and has a warranty. I will be taking the unit apart to see the build quality and how it's constructed.
    Pros-
    -Build quality well exceeds its price
    -sound quality well exceeds its price
    -all in one integrated with bluetooth, line in, and line out
    -tone controls boosted the bass slightly without degrading the sound
    Cons-
    -Bass shy (I don't know if that a design issue, or the limited power)
    -Stock Chinese tubes are the cheapest (maybe contributes to the bass response?)
    -volume is a little unbalanced at the bottom of the pot
  • Conradicles
    Got mine today. Very nice looking unit for the money. Build quality is great. Now to figure out which speakers to pair it with...
    tonyb wrote: »
    There's a handy window behind the one here. B)
    zingo wrote: »
    Not sure why you'd even want to finish the cabinets; they look great as is (at least in the photo).
    Did you make the horns yourself?
  • zingo
    zingo Posts: 11,258
    The cabinets are MDF which always looks unfinished to me if you don’t do something with it. Is that weird?
    The cherry horns were turned by a gentleman much more talented than I.
    Nope, not weird at all :) I couldn't tell what the cabinets were from the photo; at the size Vanilla reproduced your image, they look nice!
    I didn't click to see it at higher resolution.
    The horns are classy.
    Sorry to go all Lt. Columbo on you, but what drivers do the horns have on them?
    Is there a thread elsewhere on the loudspeakers?
    I'll stop now, I promise! :p
  • rooftop59
    rooftop59 Posts: 8,120
    The speakers look really cool from a distance, but zooming in I see why you’d want to finish them. I agree about mdf. If they were Baltic birch or something like that I would say poly and be done.
    Did you build the crossovers or does parts express have a kit?
    Game Room 5.1.4:
    Bedroom 2.1
  • zingo
    zingo Posts: 11,258
    I did build the crossovers using modeling software with a few different version. The sound quality and frequency response I have now is amazing, except I think the absolute phase is slightly off which I need to trouble shoot.
    The tweeters are Vifa XT25TG30-04 and the waveguide profile was taken from Zaph Audio website. Enclosures were scaled similarly to PMC twenty series.
    618413d1495898638-waveguide-transmission-line-monitors-img_6689-jpg
    618414d1495899031-waveguide-transmission-line-monitors-image-png
