Rated vs. Actual Power & Volume Control
So, I’ve got a question concerning power.
Let’s say an amplifier is rated to 300w RMS (20-20000hz). Now let’s say my speaker is only rated to 250w. Volume control goes from -80 dB to +16.5 dB. At what volume level would it actually be safe to use this amp/speaker combo?
I’m figuring as long as I don’t turn it above, say -20 or so? Any input would be welcomed.
  • Nightfall
    Nightfall Posts: 10,084
    60% of the time it works every time.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • BlueFox
    BlueFox Posts: 15,251
    Use your ears. When it sounds bad, turn it down. If you feel technical then buy a Sound Pressure Level meter so that you can put a number on what you hear. Of course, this assumes you have ‘normal’ speakers that will let you know they are hurting. :)
  • alucididea
    alucididea Posts: 113
    ZLTFUL wrote: »
    *note 78% of all statistics are made up on the spot*
    My thoughts exactly.
    BlueFox wrote: »
    I agree with that. I guess I’m trying to create a general rule of thumb for myself.
  • BlueFox
    The problem, to me, is that volume controls have different meanings in different setups. A number in one setup doesn’t necessarily relate to another setup.
  • alucididea
    BlueFox wrote: »
    Fair enough.
  • mpitogo
    mpitogo Posts: 516
    alucididea wrote: »
    I would ignore the power (unless it’s clipping). The volume control suggests your preamp is able to calibrate to reference levels. At common THX levels -20db on the volume knob should produce around 85db from the speakers. This is a normal listening level and doubt you would be overdriving and pushing more than a few watts. If you know what your speakers maximum output db is it would be relatively easy to derive the max volume level and compute the power.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
